CUCM Console Message - License Message
biplobkhan
The following warning is being displayed in CUCM admin console:
The system is operating with an insufficient number of licenses. If additional licenses to cover the shortage are not configured in your Cisco Prime License Manager within 174 days, you will no longer be able to provision users and devices.
would anyone please tell what is the problem ?
Iqbal
2 Accepted Solutions
[+5] to Manish.
Hi Khan,
You can login into PLM and check under Monitoring---Dashboard or Monitoring --License Usage [Table View/Chart] to see what all licneses have been installed /used/loaned/borrowed.
Accordingly, u can decide to have new licenses
regds,
aman
Hi Iqbal,
you can click on " synchronize now " from PLM andclick on System ---Licensing---Update usage details from CUCM to do the synchronisation immediately after u add any phone.
8945 uses UCL Enhanced and attached snapshots are fine.
regds,
aman
8 Replies 8
Manish Gogna
Hi Iqbal,
This refers to License Overage which means that the system is operating with an insufficient number of licenses. Configure additional licenses in your Cisco Prime License Manager in order to restore the ability to provision users and devices.  You should contact TAC licensing team.
Manish
[+5] to Manish.
Hi Khan,
regds,
aman
HI Manish
Thanks.  I am purches License LIC-CUCM-10X-ENHA-A
( ENhanced Single User-Under 1K ) QTY-10
UCSS-U-UCM-A-1-1 ( ENH User one Year Sub Tier)  qty-10
LIC-CUCM-10X-ESS-A          QTY-240
UCSS-UUCMESS-A-1-1        QTY-240
JABBER-1M-RTU
UCM-PAK
LIC-CUCM-10X-ENH
LIC-CUCM-1 OX-ESS
CP-3905=  qty-240
Iqbal
Hi Iqbal,
Unable to open the attachment.
what I can understand is that you have got 10 enhanced licenses and 240 essential licenses?
when u check in PLM , under Table/Chart View , are u getting any Non-compliance message or any licnese which has been loan/borrowed?
regds,
aman
HI Aman
Our vedio Phone 10  (CP-8945) and SIP Phone 240 ( CP-3905)
So, Enhanced LIC-CUCM-10X-ENH-A  qty-10 and  Essential User LIC-CUCM-10X-ESS-A  Qty-240.
Please find here the attachemnt JPEG File if trouble in open then share your mail address.
today morning after syncronization  the console message not appear. so the problem was for not synchonization ?
Iqbal khan
biplobk2000@gmail.com
Hi Iqbal,
regds,
aman
Hi Aman
Thanks for your support. It will help in next time.
Iqbal
HI Aman
I have checked according your instruction and attachment in here.
After push the license i am not synchronize. when I push syncronize the warraning messgae not appear. so this is the Synchonization problem ??
