VG350 Uplinks
Ryan Curry
Has anyone had any experience connecting a VG350 to a switch stack?  I see that there's an option to create a port-channel, but I can't configure the interfaces with the "channel-group" command.  Ideally I'd like to have a cross-stack etherchannel (layer 2) with layer 3 connectivity to a loopback interface; regardless I'd like to have a redundant solution in place.  In theory we could utilize a BVI but that's not a road I want to go down right now.
Any suggestions are appreciated.
gosselic
I'm hitting the same limitation. I wonder if there were VG code improvement since you posted this on the forum...
Thansk!
-Carl
I ended up connecting the interfaces back to the stack via L3 connections then injected my loopback address into the routing process.  It's not the straight L2 connection I wanted but it works.
kapil.atrish
Level 4
Level 4
Looks like there is a Data license needed.
SL-VG350-DAT-K9
Cisco VG350 Data License for LAN side redundant link configuration.
Kapil
