12-18-2013 11:48 AM - edited 03-16-2019 08:56 PM
Hello Community, the sip provider send us the authentication name in sip invite header instead of the called party. The called party in the field "to" is right. I try to use sip profiles to manipulate the voice gateway that they look into the "to" field for the calling party, but I it works not.
Have I any chance to manipulate the voice gateway that they looks into the "to" field?
Any help are appreciate.
Thanks Armin
549051: Dec 18 18:27:54.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=D2000101000, Called Number=D2000101000, Peer Info Type=DIALPEER_INFO_SPEECH
HTH, please rate all useful posts!
Solved! Go to Solution.
12-19-2013 08:17 AM
NB: this is an update on my last post..I deleted it
I can see that you are doing early offer on your CUBE. Do you have inbound and outbound fast start enabled on CUCM? You need to enable fast start for the H323 gateway on CUCM. You are going to need an MTP for this, so ensure you have one..Then do another test call and send me the ff logs..
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
debug ccsip messages
Please use this link to learn how to properly collect logs. Attach the logs here, dont paste them..
https://supportforums.cisco.com/docs/DOC-16310
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
12-18-2013 01:58 PM
Try this..
voice class sip-profiles 1
request INVITE sip-header TO copy "<>" u01
request INVITE sip-header SIP-Req-URI modify “.*@(.*)” “INVITE sip:\u01@213.777.22.11:5060 SIP/2.0>
Then you need to add this profile to your inbound dial-peer...
Test again and send us debug ccsip messages
12-18-2013 02:07 PM
You can also try this if that doesnt work..
request INVITE peer-header TO copy "<>" u01
12-19-2013 05:02 AM
Hi, thanks for your help.
request INVITE sip-header TO copy "<>" u01>
also not work because I have no "copy" command only modify.
12-19-2013 05:18 AM
You need Ios 15.1(3)T and above for you to use this feature..I suggest you upgrade your CUBE IOS
12-19-2013 05:31 AM
Really Really Thanks to you!!!!! We have no Cube it is a normal Router.
I will upghrade an come back to you.
12-19-2013 06:11 AM
Hi, good news. The Provider change the header! We get now the right called Party in URI and the phone at CUCM rings when we get a inbound call !!!!!!!!!
But step, by step.
The phone rings and when I pick up the Phone the calling party have still ring tone and wen have no connection. I hang up the the called party and the calling party also have still ringtone and the called party also rings again. In H323 Trace it seems when the Phone hang up the VGW get this Information. But why VGW not send 200 OK when I pick up the phone to confirm the inbound invite from Provider?
Any help are appriciate. The Trace from our Router point of view is attached.
tkvgw: Dec 19 14:53:41.761: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+49XXXXXXXXXXX@333.222.11.93:5060 SIP/2.0
Record-Route: <213.218.12.2>213.218.12.2>
Record-Route: <213.218.28.100>213.218.28.100>
Via: SIP/2.0/UDP 213.218.12.2;branch=z9hG4bK39c3.7ffb4b12.0
Via: SIP/2.0/UDP 213.218.28.100;branch=z9hG4bK39c3.9587b075.0
Via: SIP/2.0/UDP 213.218.28.164:5060;branch=z9hG4bK00E0F5100556C36E9D6F9804202F
From: "+4911111111111" <>>+4911111111111@domain-voice.com;user=phone>;tag=00E0F5100556C36E9D6FC6403C09
To: <>>+49XXXXXXXXXXX@domain-voice.com>
Call-ID: e410e00004f5-52b2fa64-67d11ce3-1ee00d80-2e7b6ac@127.0.0.1
CSeq: 33547 INVITE
Contact: <>>
Max-Forwards: 68
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, PRACK, INFO, REFER, NOTIFY, SUBSCRIBE, UPDATE
Content-Type: application/sdp
Supported: 100rel, timer, replaces
P-Asserted-Identity: <>>+4911111111111@domain-voice.com>
Remote-Party-ID: <>>+4911111111111@domain-voice.com>;party=calling;screen=no;privacy=off
Content-Length: 441
v=0
o=- 2933601919 0 IN IP4 213.218.12.2
s=session
c=IN IP4 213.218.12.2
t=0 0
m=audio 10962 RTP/AVP 8 0 18 2 96
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:2 G726-32/8000
a=sendrecv
a=rtpmap:96 telephone-event/8000
m=image 10964 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxUdpEC:t38UDPRedundancy
a=T38FaxRateManagement:transferredTCF
552557: Dec 19 14:53:41.789: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 213.218.12.2;branch=z9hG4bK39c3.7ffb4b12.0,SIP/2.0/UDP 213.218.28.100;branch=z9hG4bK39c3.9587b075.0,SIP/2.0/UDP 213.218.28.164:5060;branch=z9hG4bK00E0F5100556C36E9D6F9804202F
Date: Thu, 19 Dec 2013 13:53:41 GMT
CSeq: 33547 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
552558: Dec 19 14:53:41.809: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <>>+49XXXXXXXXXXX@domain-voice.com>;tag=FA6FA0C4-26B8
CSeq: 33547 INVITE
Require: 100rel
RSeq: 6869
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <27>;party=called;screen=no;privacy=off27>
Contact: <>>
Record-Route: <213.218.12.2>,<213.218.28.100>213.218.28.100>213.218.12.2>
Content-Length: 0
552559: Dec 19 14:53:41.825: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:+49XXXXXXXXXXX@192.168.1.233:5060 SIP/2.0
Via: SIP/2.0/UDP 213.218.12.2;branch=z9hG4bK1ac3.c58f4862.0
Via: SIP/2.0/UDP 213.218.28.100;branch=z9hG4bK1ac3.f3211d34.0
Via: SIP/2.0/UDP 213.218.28.164:5060;branch=z9hG4bK00E0F5100556C36E9D7E1CC3731F
CSeq: 33548 PRACK
Contact: <>>
Max-Forwards: 68
RAck: 6869 33547 INVITE
Content-Length: 0
tkvgw#
552560: Dec 19 14:53:41.837: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 213.218.12.2;branch=z9hG4bK1ac3.c58f4862.0,SIP/2.0/UDP 213.218.28.100;branch=z9hG4bK1ac3.f3211d34.0,SIP/2.0/UDP 213.218.28.164:5060;branch=z9hG4bK00E0F5100556C36E9D7E1CC3731F
CSeq: 33548 PRACK
Content-Length: 0
tkvgw#
552561: Dec 19 14:53:45.313: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
tkvgw#
552562: Dec 19 14:53:55.761: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 33547 INVITE
Require: 100rel
RSeq: 6870
Contact: <>>
Content-Length: 0
552563: Dec 19 14:53:55.777: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 213.218.12.2;branch=z9hG4bK0ac3.979e4c03.0
Via: SIP/2.0/UDP 213.218.28.100;branch=z9hG4bK0ac3.639bf9a4.0
Via: SIP/2.0/UDP 213.218.28.164:5060;branch=z9hG4bK00E0F5100556C36EA2F2D10D6935
CSeq: 33549 PRACK
Contact: <>>
Max-Forwards: 68
RAck: 6870 33547 INVITE
Content-Length: 0
tkvgw#
552564: Dec 19 14:53:55.781: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 213.218.12.2;branch=z9hG4bK0ac3.979e4c03.0,SIP/2.0/UDP 213.218.28.100;branch=z9hG4bK0ac3.639bf9a4.0,SIP/2.0/UDP 213.218.28.164:5060;branch=z9hG4bK00E0F5100556C36EA2F2D10D6935
Date: Thu, 19 Dec 2013 13:53:55 GMT
CSeq: 33549 PRACK
Content-Length: 0
tkvgw#
552565: Dec 19 14:53:57.765: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:+4911111111111@213.218.28.164:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.233:5060;branch=z9hG4bK1A671B33
From: <>>+49XXXXXXXXXXX@domain-voice.com>;tag=FA6FA0C4-26B8
To: "+4911111111111" <>>+4911111111111@domain-voice.com;user=phone>;tag=00E0F5100556C36E9D6FC6403C09
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Timestamp: 1387461237
CSeq: 101 UPDATE
Contact: <>>
Remote-Party-ID: <4599>;party=called;screen=yes;privacy=off4599>
Content-Length: 0
552566: Dec 19 14:53:57.789: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
tkvgw#SIP/2.0 200 Ok
Via: SIP/2.0/UDP 192.168.1.233:5060;rport=53642;received=333.222.11.93;branch=z9hG4bK1A671B33
CSeq: 101 UPDATE
Contact: <>>
Content-Length: 0
tkvgw#
552567: Dec 19 14:54:00.793: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 408 Request Timeout
CSeq: 33547 INVITE
tkvgw#
Reason: Q.850;cause=102
Content-Length: 0
552568: Dec 19 14:54:00.801: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+49XXXXXXXXXXX@333.222.11.93:5060 SIP/2.0
CSeq: 33547 ACK
Content-Length: 0
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
tkvgw#
554191: Dec 19 15:31:55.743: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30 disconnected from 06926547915 , call lasted 53 seconds
tkvgw#debug cch323 all
All CCH323 call tracing is enabled
tkvgw#
554192: Dec 19 15:32:06.280: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected to 01624076331 N/A
tkvgw#
554193: Dec 19 15:32:08.004: //-1/xxxxxxxxxxxx/H323/cch323_indicate_rt_packet_stats: callID=204097
554194: Dec 19 15:32:08.008: //-1/xxxxxxxxxxxx/H323/cch323_do_process_statistics: Entry, call_id=204097
554195: Dec 19 15:32:08.976: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
554196: Dec 19 15:32:08.976: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x4BC759C8, len=126, msgPtr=0x4BA12FC0
554197: Dec 19 15:32:08.976: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
554198: Dec 19 15:32:08.976: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPCFM_CHOSEN
554199: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/setup_cfm_ind: ====== PI = 0
554200: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/setup_cfm_ind: Set new event H225_EV_SETUP_CFM_IND
554201: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/setup_cfm_ind: Call Manager detected
554202: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/cch323_h225_receiver: SETUPCFM_CHOSEN: src address = 192.168.1.233; dest address = 192.168.1.213
554203: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/run_h225_sm: Received event H225_EV_SETUP_CFM_IND while at state H225_REQ_FS_ALERT
554204: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/h245_address_ind: ev=4
554205: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/setup_cfm_notify: status = 48100009
554206: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_ALERT state to H225_WAIT_FOR_H245 state
554207: Dec 19 15:32:08.976: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xB internal event to H245 IWF SM
554208: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECT_REQ while at state IWF_IDLE
554209: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_CONNECT_REQ_EVENT
554210: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/cch323_h245_connection_sm: state=0, event=1, ccb=4B0B622C, listen state=0
554211: Dec 19 15:32:08.976: //204156/2A2AE0F1ACD4/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_CONNECT_REQ_EVENT while at H245_NONE state
554212: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
554213: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/h245_iwf_set_new_state: changing from IWF_IDLE state to IWF_AWAIT_H245_CONN state
554214: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/h245_connect_init: connection pending
554215: Dec 19 15:32:08.980: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
554216: Dec 19 15:32:08.980: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x4BC759C8, len=50, msgPtr=0x483C7B64
554217: Dec 19 15:32:08.980: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
554218: Dec 19 15:32:08.980: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type NOTIFYIND_CHOSEN
554219: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/notify_ind: Entry
554220: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/notify_ind: Rcvd NOTIFY Notification Indicator IE = 113
554221: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/notify_ind: Rcvd NOTIFY Connected Number as IE
554222: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/notify_ind: [cnum]/[oct]/[oct3a]= [27]/[0x00]/[0x81]
554223: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/cch323_put_embedded_obj_to_ccb: ccb=0x4B0B622C, tag=14, size=144
554224: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/cch323_put_embedded_obj_to_ccb: Insertion PASSED, embedded at 0x49513980
554225: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/notify_ind: Notify data embedded, mask=0x00000005
554226: Dec 19 15:32:08.980: //204156/2A2AE0F1ACD4/H323/cch323_h225_receiver: NOTIFYIND_CHOSEN: src address = 192.168.1.233; dest address = 192.168.1.213
554227: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/run_h225_sm: Received event H225_EV_NOTIFY_IND while at state H225_WAIT_FOR_H245
554228: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/notify_msg_notify: Entry
554229: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/notify_msg_notify: Notify data found, mask=0x00000005
554230: Dec 19 15:32:08.984: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
554231: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/cch323_h245_channel_established_ind: Using fd=3 to send msgs
554232: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_ESTABLISHED_EVENT
554233: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/cch323_h245_connection_sm: state=1, event=2, ccb=4B0B622C, listen state=0
554234: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_ESTABLISHED_EVENT while at H245_WAITING state
tkvgw#
554235: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/cch323_h245_set_new_state: Changing from H245_WAITING state to H245_CONNECTED state
554236: Dec 19 15:32:08.984: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x2 internal event to H245 IWF SM
554237: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECTED while at state IWF_AWAIT_H245_CONN
554238: Dec 19 15:32:08.984: //204156/2A2AE0F1ACD4/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_H245_CONN state to IWF_H245_CONNECTED state
554239: Dec 19 15:32:08.984: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
tkvgw#un all
12-19-2013 06:28 AM
Hi again, the Provider gave me this information, he need from me a "200_OK" as comfirmation when I pick up the Phone from CUCM. But VGW don´t sent 200OK as confirmation for the invite.
After time the VGW sent a Time out as confirmation for the Invite.
12-19-2013 07:02 AM
Yes they are correct, the gateway is not sending 200 OK.. Can you describe your setup? Is this a CCME gateway connected to ITSP??
Please send your sh run
12-19-2013 08:05 AM
Hi, Ip Phone 7975 -- CUCM -- H323 -- VGW 2811 | --> SIP Trunk ITSP
| --> E1 PSTN
Building configuration...
no voice call carrier capacity active
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol pass-through g711alaw
h323
emptycapability
no h225 timeout keepalive
h225 id-passthru
h245 passthru tcsnonstd-passthru
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
header-passing
localhost dns:voice.de
outbound-proxy dns:voice.de
early-offer forced
voice class codec 1
codec preference 1 g711alaw
voice class h323 1
h225 timeout tcp establish 2
h225 timeout setup 2
call preserve
voice class sip-profiles 76
request INVITE sip-header From modify "<>>49123456789@voice.de" "<>>D2000101000@voice.de"
voice translation-rule 1
rule 1 /^00\([1-9].*\)/ /\1/ type national national plan isdn isdn
rule 2 /^000\([1-9].*\)/ /\1/ type international international plan isdn isdn
rule 3 /^49\(111111.*\)/ /\1/ type any national plan any isdn
rule 4 /\(^011111.*\)/ /\1/ type unknown unknown plan unknown unknown
rule 5 /^45..$/ /6111111\0/ type unknown national plan unknown isdn
voice translation-rule 2
rule 1 /^1111/ /91/
rule 2 /^91111/ /99/
rule 3 /^911111\(.*\)/ /\1/
voice translation-rule 3
rule 1 /^\([1-9].*\)/ /00\1/ type national national plan isdn isdn
rule 2 /^\([1-9].*\)/ /000\1/ type international international plan isdn isdn
rule 3 /^\([1-9].*\)/ /006157\1/ type subscriber national plan isdn isdn
voice translation-rule 4
rule 1 /^0\([1-9].*\)/ /\1/ type unknown unknown plan unknown unknown
rule 2 /^00\([1-9].*\)/ /\1/ type unknown national plan unknown isdn
rule 3 /^000\([1-9].*\)/ /\1/ type unknown international plan unknown isdn
voice translation-rule 6
rule 1 /^760\([0-9].*\)/ /+49\1/
voice translation-rule 7
rule 1 /^\+4912345678911/ /11/
rule 2 /^\+4912345678913/ /13/
rule 3 /^\+4912345678914/ /14/
rule 4 /^\+4912345678915/ /15/
rule 5 /^\+4912345678916/ /16/
rule 6 /^\+4912345678917/ /17/
rule 7 /^\+4912345678921/ /21/
rule 8 /^\+4912345678927/ /22/
rule 9 /^\+4912345678924/ /24/
rule 10 /^\+4912345678925/ /25/
rule 11 /^\+4912345678928/ /28/
rule 12 /^\+4912345678929/ /40/
voice translation-profile AMT_IN
translate calling 3
translate called 2
voice translation-profile AMT_OUT
translate calling 1
voice translation-profile SIP_AMT_IN
translate called 7
voice translation-profile SIP_AMT_OUT
translate called 6
voice translation-profile called_outgoing_PSTN
translate calling 30
translate called 10
voice translation-profile calling_incoming_pstn
translate calling 20
translate called 40
controller E1 0/0/0
pri-group timeslots 1-31
description Trunk zu TKSW1
ip address 333.111.1111.233 255.255.255.0
duplex full
speed 100
h323-gateway voip interface
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
description Anschluss Amt fuer POTS
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 3000
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
no cdp enable
voice-port 0/0/0:15
translation-profile incoming AMT_IN
translation-profile outgoing AMT_OUT
cptone DE
bearer-cap 3100Hz
dial-peer voice 10 voip
description to CUCM
translation-profile outgoing SIP_AMT_IN
preference 5
destination-pattern .T
progress_ind setup enable 3
modem passthrough nse codec g711alaw
voice-class h323 1
session target ipv4:333.222.1111.444
dtmf-relay h245-alphanumeric rtp-nte h245-signal
codec g711alaw
fax-relay ecm disable
fax nsf 000000
no vad
dial-peer voice 11 voip
translation-profile incoming SIP_AMT_IN
preference 1
voice-class h323 1
session target ipv4:333.222.1111.555
codec g711alaw
fax rate disable
fax nsf 000000
no vad
dial-peer voice 100 pots
tone ringback alert-no-PI
destination-pattern 0T
progress_ind alert enable 8
progress_ind connect enable 8
fax rate disable
direct-inward-dial
port 0/0/0:15
dial-peer voice 40 pots
service stcapp
fax rate disable
port 0/1/0
dial-peer voice 5039 pots
service mva
incoming called-number 39
direct-inward-dial
dial-peer voice 600 pots
destination-pattern 6T
direct-inward-dial
port 0/2/0:15
forward-digits all
dial-peer voice 43 pots
service stcapp
fax rate disable
port 0/1/3
dial-peer voice 76 voip
translation-profile outgoing SIP_AMT_OUT
destination-pattern 76T
voice-class sip profiles 76
session protocol sipv2
session target dns:voice.de
session transport udp
codec g711alaw
dial-peer voice 80 voip
incoming called-number .T
codec g711alaw
sip-ua
credentials username D2000101000 password 7 1111111111111111111111111111111 realm voice.de
authentication username D2000101000 password 7 11111111111111111 realm voice.de
registrar dns:voice.de expires 3600
sip-server dns:voice.de
tkvgw#
12-19-2013 08:17 AM
debug h225 asn1
debug h245 asn1
12-19-2013 09:34 PM
Good morning, you are 100% right!!!! Meantime I found a very good documentation, the content is very helpful and describe my szenario. I set fast start in/out and MTP and it works. But I will go ahead and change CUCM - VGW to a SIP Trunk, it is the better way.
Many thanks for your support, one more happy customer!!!!
HTH, please rate all useful posts and Documentation!
12-20-2013 01:59 AM
Glad I could help..Please mark the thread as answered, so as to help others in the future
12-20-2013 03:54 AM
At this place a short note for Cisco. It is all the time a big, no a very big big battle to find a "pragmatic" documentation that cover the most common szenarios and not explain a command or parameter hundret of times. I mean this books over 1000 pages.... and so on....
Explain Szenario and show step by step which parameter you should set!
Cisco create so many documentation, but to less "pracmatic" documentation.
For example, why I need a CUBE, in my case I Solve the Szenario w/ only a Router w/o CUBE functionality.
How and where I could find a docu Router SIP vs. CUBE functionality in short setence? I would not read the whole docu for Voice GW and Cubes to find some differences.
12-20-2013 04:03 AM
Cisco is the best in documentation and if you look very well on this forum you will find a documentation for what you are trying to achieve. I suggest you take some time to know what a CUBE is..In your scenario you need a CUBE. When you need to connect two different voip legs, you need a CUBE, you cant just use a gateway and this is well documented...
