VIC-2BRI-NT/TE Installation
mehmoodch
I recently purchased cisco 2901 router and installe CME 8.6. I already have
VIC2-2BRI-NT/TE card installed in the cisco 2611XM router. The 2611XM router will be repalced with 2901 router.
But cisco 2901 did not detected the VIC2-2BRI-NT/TE card. The IOS image on 2901 is c2900-universalk9-mz.SPA.151-4.M1.bin.
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
at the above link I found that this card will be compatible with 2901 router but the image should be
Cisco IOS Software Release 15.0(1)M
"UC Technology" images
I dont know what it means by UC technology images. If the current IOS is not UC technology then which IOS will be US technolgy comatianble to CME 8.6?
Can anyone please help me to install that BRI card.
Mahmood
2 Accepted Solutions
Hi Mahmood,
Thanks for the details. Yes, that is the issue. VIC-2BRI-NT/TE is Gen 1 which is not supported on ISR G2 platforms while VIC2-2BRI-NT/TE is Gen 2 which is supported.
Please refer to the following doc which talks about the supported platforms for this card:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b16.shtml#ps
HTH.
Harmit.
Hi Mahmood,
I'm glad I could help :-)
Yes, VIC2 is supported as per the 1st doc I provided yesterday and would work just fine on the 2901 with the current IOS.
Harmit.
12 Replies 12
Harmit Singh
Hi Mahmood,
Looking at the data sheet for the VIC card in question, I can see that it is supported on the 2900 series as well as the IOS installed on your 2901:
Having said that, do you have PVDMs installed on the router? If not, that is probably why it's not getting detected.
HTH.
Harmit.
Hi Marmeet
Thanks a lot for your reply. Can you please tell me how to install PVDMs
Mahmood
Hi Mahmood,
Sure no problem.
Regarding PVDMs, the following document talks about them in more detail:
http://www.cisco.com/en/US/prod/collateral/modules/ps3115/data_sheet_c78-553971_ps10537_Products_Data_Sheet.html
I would also suggest visiting the DSP calculator to see how many PVDMs are required for the cards being installed as well as the configuration being done on this gateway:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Harmit.
Harmit Singh
Hi Mahmood,
UC technology images would ideally refer to if you have UC licenses installed on the router or not. You can check that in "show version" output. Kindly upload the following outputs:
show version
show inventory
show diag
Harmit.
Hi Harmeet
The router is in our Cyprus office and powered off this time. I will power up tomorrow and send you the outputs.
Mahmood
mehmoodch
Hi  Harmeet,
The card is VIC-2BRI-NT/TE not VIC2-2BRI-NT/TE
Please find the output of the above commands. I installed the VIC-2BRI-NT/TE card into the router. from show diag commands it looks tha card has been detected but I cant see in show inventry or hardware commands.
Cyp-2901-01#Cyp-2901-01# show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 14-Jun-11 19:25 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Cyp-2901-01 uptime is 33 minutes
System restarted at 16:58:47 EET Thu Jan 3 2013
System image file is "flash:c2900-universalk9-mz.SPA.151-4.M1.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ164390Q9
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2901/K9 FCZ164390Q9
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
Cyp-2901-01#show diag
Slot 0:
        C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 00:31:54 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC16334TA0
        Hardware Revision        : 1.0
        Part Number              : 73-11834-09
        Top Assy. Part Number    : 800-30795-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2901/K9
        Version Identifier       : V05
        CLEI Code                : CMMHB10ARA
        Processor type           : C1
        Chassis Serial Number    : FCZ164390Q9
        Chassis MAC Address      : fc99.4780.cc98
        MAC Address block size   : 72
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 33 33 34 54 41 30 40
          0x10: 06 17 41 01 00 82 49 2E 3A 09 C0 46 03 20 00 78
          0x20: 4B 05 42 41 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 35 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 42 31 30 41 52
          0x50: 41 09 C1 C2 8B 46 43 5A 31 36 34 33 39 30 51 39
          0x60: C3 06 FC 99 47 80 CC 98 43 00 48 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC164047GF
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
        Version Identifier       : V01
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 34 30
          0x20: 34 37 47 46 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        NT or TE BRI Voice daughter card (2 port)
        WIC module not supported/disabled in this slot
        Hardware revision 1.0           Board revision C0
        Serial number     26682275      Part number    800-07272-03
        FRU Part Number     VIC-2BRI-NT/TE=
        Test history      0x0           RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
          0x20: 01 32 01 00 01 97 23 A3 50 1C 68 03 00 00 00 00
          0x30: 60 00 00 00 01 10 17 00 FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
Cyp-2901-01#show inventory
NAME: "CISCO2901/K9 chassis", DESCR: "CISCO2901/K9 chassis"
PID: CISCO2901/K9      , VID: V05 , SN: FCZ164390Q9
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC164047GF
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC  , VID:    , SN:
Cyp-2901-01#show hardware
Cyp-2901-01 uptime is 10 minutes
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device#   PID                   SN
data          None          None           None
Hi Mahmood,
HTH.
Harmit.
Thanks Harmit. I should buy a new VIC2-2BRI-NT/TE card?
Becasue from the refrence doc this card is not compatible with 2901 router and  its IOS
Hi Mahmood,
Harmit.
mehmoodch
Hi Harmit
Thanks a lot for your help. I am ordering this card and let you know after installation.
Mahmood
Hi Mahmood,
Sure thing! Thanks for the nice rating :-)
Harmit.
