01-11-2014 08:50 PM - edited 03-16-2019 09:12 PM
How do I tell if my router is recognizing the VIC-2FXO-M1 card I put in it? I want to confirm the card is working, but I don't know how to tell if it is working or recognized since I purchased it used.
Mitch
Solved! Go to Solution.
01-11-2014 09:19 PM
The command "sh inventory" should be the first step.
01-11-2014 10:38 PM
Hi Mitchell,
In addition to what Mr Leo has said, u can also try show diag and also need to have Voice image .You should get the output something like Unknown Port Adaptor.
But ,I doubt the card is supported on 2800 series.
Please check the links
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b53c7.shtml
regds,
aman
01-12-2014 04:56 AM
Aman seems to be right, this module is not supported on 28XX series
Br,
Nadeem
Please rate all useful post.
01-11-2014 09:19 PM
01-11-2014 10:38 PM
Hi Mitchell,
regds,
aman
01-12-2014 04:56 AM
Br,
Nadeem
01-12-2014 09:50 AM
I get this when I run 'sh inventory'
PID: CISCO2811 , VID: V03 , SN: FTX2341A07T
Well that sucks if it doesn't support it. I was told it would because originally it had a T1 card in it and it has 4 WVIC slots 0-3.
I also have a 2821, but it doesn't have an IOS on it yet, waiting for the memory and CF card to arrive to update it.
01-12-2014 09:54 AM
I also ran 'sh diag' and I got this result:
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware revision 1.0 Board revision F0
Serial number 30276198 Part number 800-05298-01
FRU Part Number VIC-2FXO-M1=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 2B 01 00 01 CD FA 66 50 14 B2 01 00 00 00 00
0x30: 78 00 00 00 03 03 28 01 FF FF FF FF FF FF FF FF
01-12-2014 09:59 AM
Well, is there any VOIP card that will work in the 2800 (2811 or 2821) routers?
Thanks!
01-12-2014 11:08 AM
Does anyone have a suggestion for a VOIP device that is compatable with this card I can get on Ebay for relatively cheap? I see the list from this page, but it looks like some of the models need a special memory module to get as well:
Thanks all. I'd rather get the best item I can from the compatability list for the card, since it looks like most of them are relatively cheap, barring they don't require the additional memory DSP module.
01-12-2014 06:03 PM
Hi Mitchell,
you can check your requirement from the above mentioned links.
Routers/Gateways | ||||||
Model | 2801 | 2811, 2821, 2851 | ||||
Voice Network Module (right) | Not Used | NM-HD-1V 1NM-HD-2V 1 | NM-HD-2VE2 | NM- HDV | NM- HDV2 | Chassis slot |
VIC (below) | ||||||
VIC-2FXO, EU | No | No | No | No | No | No |
VIC-2FXO-M1/M2/M3 | No | No | No | No | No | No |
VIC-2FXS | No | No | No | No | No | No |
VIC-2E/M | No | No | No | No | No | No |
VIC-2BRI-S/T-TE | No | No | No | No | No | No |
VIC-2BRI-NT/TE | No | No | No | No | No | No |
VIC-2DID | Yes | Yes | Yes | No | Yes | Yes |
VIC-2CAMA | No | No | No | No | No | No |
VIC-1J1 | No | No | No | Yes | Yes | No |
VIC-4FXO-M1 | No | No | No | No | No | No |
VIC-4FXS/DID | Yes | Yes3 | Yes3 | No | Yes3 | Yes3 |
VIC2-4FXO (FXO/CAMA) | Yes | Yes | Yes | No | Yes | Yes |
VIC2-2FXO (FXO/CAMA) | Yes | Yes | Yes | No | Yes | Yes |
VIC2-2FXS | Yes | Yes | Yes | No | Yes | Yes |
VIC2-2E/M | Yes | Yes | Yes | No | Yes | Yes |
VIC2-2BRI- NT/TE | Yes | Yes | Yes | No | Yes | Yes |
VWIC-xMFT-E1 (with or without DI) | Yes | No | Yes | Yes | Yes | Yes |
VWIC-1MFT-G703 | Yes | No | No | No | Yes | Yes |
VWIC-2MFT-G703 | Yes | No | No | Yes | Yes | Yes |
VWIC-xMFT-T1 (with or without DI) | Yes | No | Yes | Yes | Yes | Yes |
as far as Memory and Flash is concerned, install ipvoice image with yor existing DRAM/Flash & check.
regds,
aman
