VIC2-4FXO to RightFax - No longer connects
Yort Mantup
Level 4
Level 4
I have had this setup for almost two years - analog line connected to FXO MGCP routing back to CUCM ---> SIP Trunk to RightFax server.   As of this morning they have stopped receiving inbound faxes.  When I test - the call connects and silence. NO fax tones.  I tested the analog line and it's good.  I know the connection from CUCM to RightFax is also good.
This issue occurs on each FXO port.  I have reset the FXO ports on the router and CUCM.  Still no connection. There were no changes on the network or power loss last night.
When I debug voip ccapi inout and debug vpm signal, nothing stands out to me which is why I'm looking for help here.  I attached the debug file below.
Environment: CUCM 8.5
RF 10.0
Router:  2911 running  15.0(1)M3
Thanks!
Yort Mantup
Level 4
Level 4
found my answer - for some reason in the MGCP config had the t38 inhibit command. Once I removed that again - faxing began working.   The router did not reboot so I am not sure why this reverted back - I seem to recall in my past life this occuring intermittently with Csico 2900 series routers but am unsure as to what triggers it.
Rob Huffman
Hi Troy,
It sounds like this bug;
CSCta26864 - MGCP fax T38 inhibit and ecm configured upon reload
Description
Symptom:
On a Cisco MGCP gateway registered to Cisco Unified Callmanager server, running
IOS 124-24T we have enabled T38. But after a reload following
command lines are seen in the configuration and all T38 faxes fail:
mgcp fax t38 ecm
mgcp fax t38 inhibit
Conditions:
Specific to MGCP T38 fax. The command "ccm-manager config" needs to be
enabled to cause this issue.
Debug capture during boot up will show:
000386: Jun 18 21:58:06.588: cmapp_xml_cfg_router: configuring
[mgcp fax t38 inhibit]
Workaround:
This issue is not seen in Cisco IOS images 124-15T9 and 124-20T3.
You can also manually configure this after the reload:
mgcp default-package fxr-package (if need be)
no mgcp fax t38 inhibit
no mgcp fax t38 ecm
and then reset the gateway from the Callmanager
Fixed in:                          (16)
15.1(24.6.12)PIL13,15.1(1.7.1)PIA14
15.1(1.5.1)PIA13,15.1(1)XB,15.1(0.7)T
15.1(0.2.7)PIB13,15.1(0.2)PI12f,15.1(0.0.3)PIL15
15.1(0.0.10)PIL14,15.0(1)M0.5,12.4(24)T2
12.4(24)MDA1,12.4(24)MD,12.4(24)GC2,12.4(22)T4
12.4(22)MDA4
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
