Video Conferencing using Cisco IP Phone 9971
azeemo157
Hi Team
I have a customer using CM 8.6 and using 9971 IP Phones with video camera. We are able to make one-to-one video calls between the ip phones. As i had told them video conferencing may not work using the media resources of Call manager. They have asked me to find what external resources will have to be used for this to work. I beleive PVDM-3 supports video conferencing but again i read it for CUCME and CUCM.
Can anyone help me with this ? Is there any oter appliance that has to be bought to achieve this like for eg:- Meeting Place server or is there a way i can use PVDM3 on VG for CUCM. IF yes how many PVDM's is required to acheive this.
Azeem
Chris Deren
This is also supported with CUCM 8.6, check out release notes:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/8_6_1/cucm-rel_notes-861a.html#wp1946345
under "Video Conferencing with Cisco Integrated Services Routers Generation 2" section.
For more info see:
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/gatecont/ps4952/qa_c67-649850.html
HTH,
Chris
Chris Deren
For more info see:
HTH,
Chris
Any chance of some links us mere mortals can access ?
GTG
Please rate all helpful posts.
Gordon,
The links should work for you if you remove the "partner" from the URL.
Chris
