Video issues between Jabber and SX20 VC device
carl_townshend
Hi All
We have just created a SIP trunk from our CUCM running 8.6 and our Cisco VC device, I think its an expressway.
We can make voice calls no problem from our IP phones, however when I try to make a video call from jabber client to a VC device, the video comes on for a second, then goes off!
Any ideas why this would be ?
cheers
Carl
Ayodeji Okanlawon
Have you checked your cucm location configuration that you have set enough bandwidth for video. You should check the location configuration for jabber and the sip trunk
Please rate all useful posts
Ayodeji Okanlawon
Thanks for this, I set the trunk to the same location as my CUCM and it worked!!
is 384K not enough?
also does location control the total amount and region do per call ?
Ideally 384k should be enough for video. Have a look at this link and it will tell you what performance expectation you should get with what badnwidth.
Location determines the amount of bandwidth available while your region sets what codec you will use for calls including video calls.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_2/JABW_BK_C9731738_00_jabber-windows-install-config/JABW_BK_C9731738_00_jabber-windows-install-config_chapter_010.html#JABW_RF_P02ECF56_00
