View status of a phone via cucm
james crowley
Is there a way of seeing if a user is busy via the cucm? I know I can ring it but I want to view the status
5 Replies 5
M02@rt37
Hello @james crowley
Configure BLF no ? and via RTMT you can view devices status I think.
Best regards
If you utilize BLF Speed Dial, for example, by configuring extension 5001 as a BLF Speed Dial on your phones, you’ll see a red light indicating that the user is busy when 5001 is on a call.
Is that the functionality you’re looking for?
Response Signature
esdesk
Put the line on your phone and watch the Icon... Otherwise they use to have Attendant Console that showed all that info
Kathy N.
If users are in Webex, you can see the status of the phone number assigned to them.  I use this often so I don't have to reprogram a button on my phone to check their status.
I also needed access to "see" what the user sees in order to support calls so we purchase licensing from Uplinx Software.  It's about $600 for a 3 year license but has really helped us with remote support.  I can see what users do on their phone in real time so it removes any communication issues for our support tickets.   Using the app, I discovered that users are able to long press a button programmed with a speed dial or BLF and program their own speed dial on it.  It does not show in CUCM and any programming done in CUCM doesn't override what they have done.  This is an undocumented feature that we opened a TAC case on and was told it's working as designed.
Response Signature
Not to go off topic, but the ability to configure those speed dials has been around since 2018 and it's documented
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/firmware/12-1-1/releasenotes/p881_b_8800-series-release-notes-1211.html#reference_6CCEC5E1E3E91CAA5E492E4DD0DC9E24
java
if this helps, please rate
