IP Telephony and Phones
Personalize banner_3
Labels
No issue. Just an FYI for all of you.I just setup RTMT v15 and found that there was no installer. Just a program folder called CiscoRTMTPlugin with a run.bat file instead of an executable. I copied the program folder to c:\program files\cisco\ . Then...
Hi, all What is the option in the cnf.xml file, that disables sdp-anat for CP-9971. Our case is calls between Asterisk and CP-9971. That calls from 9971 to Asterisk ends with SIP 420 'unsupported required extension: required: unsupported:sdp-anat'. A...
ren fau by Community Member
  • 958 Views
  • 1 replies
I'm having a weird issue on our Cube. I have an incoming dial peer that should match outgoing calls to any number with 000 dial-peer voice 1120 voiptranslation-profile incoming add_plussession protocol sipv2session transport udpdestination dpg 999inc...
Djeten by Level 5
  • 2153 Views
  • 14 replies
