Viewmail 8.0.3
dcagampan
ENVIRONMENT:
Unity 5.0.1
Windows 7 Enterprise 32-bit
Exchange 2007
MS Outlook 2007
We recently upgraded our Viewmail client on some test workstations from 7.0.2 to 8.0.3 and noticed a significant delay in playback. Also, the progress bar is not synchonized with the playback as it was in previous versions of Viewmail. I found no literature indicating VMO 8.0.3 did not support Unity 5.0.1.  Any thoughts?
paolo bevilacqua
They broke something that was working fine, and due to poor testing, did not even realized. That happens a .lot.
Either you downgrade, or open a TAC case and fight uphill to see the issue acknowledged and fixed.
paolo bevilacqua
Okay, I will try that and I'll post the results.
This is TAC's response:
"Per your case, you are hitting defect
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtd90466
Defect indicates that this should be corrected in VMO 8.1."
It looks like I will have to wait until 8.1 it seems.
