Vodafone SIP with CUBE
Mark Barton
Hello
I have a new SIP service with Vodafone in Italy and am struggling to configure my CUBE correctly.
Does anyone have a working configuration I can use as a template please?
I have attached the Vodafone doc for reference.
Mark
5 Replies 5
George Sotiropoulos
Hello Mark,
I have sent you a template from Cube with VF located at Europe on a personal email.
G
Hope the above helps,
gsotirop
Thanks, will test tomorrow, and let you know how it goes
OK, you may need to post your running-config tomorrow, for faster troubleshooting.
G.
gsotirop
Hello Mark,
Did you manage to connect with the Provider and make it work?
G
gsotirop
Still struggling I am afraid, the call never seems to get further than the CUBE. I am seeing a service unavailable error which I am interpreting as no connection to SBC, but tried various different combinations of config to no avail.
Below is current version and previous version, nether work, plus attached a debug for good measure
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname ITROM1-VG4351-01-01
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
clock summer-time IT recurring last Sun Mar 1:00 last Sun Oct 2:00
ip host ims.vodafone.it 10.115.33.209
ip name-server 10.115.33.212 10.115.33.216
subscriber templating
crypto pki trustpoint TP-self-signed-2981348664
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2981348664
 revocation-check none
 rsakeypair TP-self-signed-2981348664
crypto pki certificate chain TP-self-signed-2981348664
 certificate self-signed 01
  30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393831 33343836 3634301E 170D3139 31303131 31343232
  34315A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39383133
  34383636 34308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100A375 6BE017EA 66A7D689 B46E04B9 B387828A D00E3F26 8C53E152
  252A3A42 FD7BD25B C2C20FBA 7F7C4494 BA9F10D0 2580585F C72B968E EA790E09
  79FECA2C 033CE8E3 761ED26D 898205F1 0E98A7DD E73E75D2 55CE02A4 1629D2E8
  580824DC EC56001C 9FA259F4 FCB04CE3 A06D5132 3BEF2348 18F6C7E1 E8B321A0
  A9308D35 FD1B1290 52E3270C 61C2F0EB 43639895 4C6090D8 6FF5BE68 08DC9941
  D1061B7C 4CC9E7C0 500ADD3F 5D82A563 ADB0CCE6 582860DF 5988046B 8581E0FB
  C9328287 08C671D1 C8FA72CD 72B38215 0F4B134E 4A9D953C ED7D4098 F9D38EEF
  C2ECD7BF 5A85F35F 5E8B310D 5FBE9F36 4CBB391C AE73FF75 DAEFE31F 2F65D4EB
  835FFF14 6B510203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 141EE7FC 061A9A2C 47FC12F4 917BD982 B6F62142
  70301D06 03551D0E 04160414 1EE7FC06 1A9A2C47 FC12F491 7BD982B6 F6214270
  300D0609 2A864886 F70D0101 05050003 82010100 65248B71 C9B83C2D F4C13AB5
  6B437902 6CA1C7B8 42CC65D4 669882E1 E250A894 4E35115E 64275F3B A9AA0920
  6EF6899B 07DA167C 09AC7E0A 030E5266 636E16C9 F5550F14 7D1A5206 E3E28F3D
  A7D84D18 3AFBD2CA 6961973E B0CC1472 749B9E1B CB0C8296 AD35DA0A FFBFFACB
  D54FA17B FC87C430 33358BCA 25BD779C 151FD849 43CA774A 0C4F5BB8 4020BA24
  6F8C93F0 95C431B6 4C2B1FDF 37AA7AAE 8E64AFBF 2E73AD60 AF6A1027 3B468063
  29572CD9 096CAAD4 2C9E6C66 E73880FC 8A5BF2BD CAAF29AC DA530AF9 254111F9
  2B8008AB 1787FD54 393AFF10 45E80B7B E2898831 3E7FA0F9 E38EF0D3 E79FC8F2
  10BE5CBC 0A6AEB96 9EB7B722 329632C6 2515B11A
        quit
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  rel1xx disable
  min-se 450 session-expires 900
  session refresh
  header-passing
  error-passthru
  registrar server
  asserted-id pai
  privacy pstn
  outbound-proxy ipv4:10.115.33.209
  no update-callerid
  midcall-signaling passthru media-change
  early-offer forced
  g729 annexb-all
  pass-thru content sdp
voice class codec 100
 codec preference 1 g729r8
 codec preference 2 g711alaw
 codec preference 3 g711ulaw
voice class sip-profiles 100
 response ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
 request ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
voice class sip-profiles 101
 request INVITE sip-header P-Asserted-Identity modify "<sip:(.*)@(.*)>" "<sip:0669270500@ims.vodafone.it>"
 request INVITE sip-header To modify "<sip:(.*)@(.*)>" "<sip:0669270500@ims.vodafone.it>"
 request INVITE sip-header From modify "<sip:(.*)@(.*)>" "<sip:0669270500@ims.vodafone.it>"
 request CANCEL sip-header Max-Forwards modify ".*" "User-Agent:CUBE"
voice class server-group 2
 ipv4 10.64.52.136 preference 2
 ipv4 10.65.32.83 preference 1
voice class server-group 1
 ipv4 10.115.33.209 preference 1
 ipv4 10.115.33.213 preference 2
voice class sip-options-keepalive 100
 description Vodaphone SIP
 transport tcp
 sip-profiles 100
voice-card 0/4
 no watchdog
license udi pid ISR4351/K9 sn FDO232610QQ
no license smart enable
diagnostic bootup level minimal
redundancy
 mode none
interface GigabitEthernet0/0/0
 description ** LAN***
 ip address 10.115.33.35 255.255.255.240
 standby 93 ip 10.115.33.37
 standby 93 preempt
 standby 93 track 1 decrement 20
 negotiation auto
interface GigabitEthernet0/0/1
 description ***Vodafone CPE1***
 ip address 10.115.33.225 255.255.255.248
 standby 10 ip 10.115.33.227
 standby 10 preempt
 standby 10 track 1 decrement 20
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface Service-Engine0/4/0
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
ip default-gateway 10.115.33.33
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 10.115.33.33
ip route 10.115.33.208 255.255.255.240 10.115.33.230
ip route 83.224.122.176 255.255.255.240 10.115.33.230
ip route 83.224.122.192 255.255.255.240 10.115.33.230
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 100 voip
 description Inbound calls from Vodaphone SIP Trunk to CUBE ***
 session protocol sipv2
 session transport tcp
 incoming called-number +44T
 voice-class codec 100
 dtmf-relay rtp-nte
 no vad
dial-peer voice 101 voip
 description *** Inbound calls from CUCM to CUBE ***
 incoming called-number .
 dtmf-relay rtp-nte
 no vad
dial-peer voice 200 voip
 description *** Outbound calls from CUBE to Rome SIP Trunk ***
 destination-pattern 0T
 session server-group 1
 voice-class sip early-offer forced
 voice-class sip profiles 101
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay sip-kpml sip-notify rtp-nte
 no vad
dial-peer voice 300 voip
 description *** Outbound LAN dial-peer From CUBE to CUCM ***
 destination-pattern +44T
 session server-group 2
 voice-class sip profiles 100
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 no vad
sip-ua
 retry invite 3
 timers trying 350
 registrar dns:ims.vodafone.it expires 3600
 sip-server dns:ims.vodafone.it
line con 0
 logging synchronous
 transport input none
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input all
ntp server 10.173.223.33 prefer
ntp server 10.173.198.30
ntp server 10.173.193.30
end
version 16.9
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
        quit
voice service voip
 sip
  rel1xx disable
  session refresh
  header-passing
  error-passthru
  asserted-id pai
  privacy pstn
  no update-callerid
  early-offer forced
  g729 annexb-all
  pass-thru headers unsupp
 transport tcp
 sip-profiles 100
voice-card 0/4
 no watchdog
redundancy
 mode none
 description *** LAN***
 standby 93 preempt
 negotiation auto
 standby 10 preempt
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
no ip http server
control-plane
 session transport udp
 dtmf-relay rtp-nte
 no vad
 dtmf-relay rtp-nte
 no vad
 signaling forward unconditional
 voice-class sip options-keepalive
 no vad
 dtmf-relay rtp-nte
 no vad
sip-ua
 retry invite 3
 timers trying 350
line con 0
 logging synchronous
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input all
end
