voice announcement
aaaaaa.d12
hi! We are retiring one of the hotline number, and we would like to have a voice announcement when the user called that number (eg. "The hotline number has been changerd to xxx".) We are using Call manager 7.x with Cisco Unity Express. What's the easiset way for me to acheive this?
I tried to create a Auto Attendant script with a Start>Play Prompt (Refer to the scrnshot attached), but it doesnt' seems to work. Is this the correct way? or is there any easier method? Thx.
Rob Huffman
Hi there,
Here's one recommended method
Configuring an Announcement-Only Mailbox
Beginning in version 7.1, you can configure announcement-only  mailboxes. These mailboxes can play the user greeting and disconnect the  call only; they cannot take any messages from callers or send messages.
Announcement-only mailboxes enable you to:
Perform any operations that can be performed on a greeting in personal mailboxes, such as recording or deleting.
Use all the new greeting types introduced by the multiple greeting feature. For more information, see the Configuring Multiple Greetings.
Configure a General Delivery Mailbox as an announcement-only mailbox.
Also, announcement-only mailboxes:
Cannot be part of everyone's list (9999)
Are counted against the mailbox license
Have a default size of 5 minutes when they are created, but the default size can be modified later
Because announcement-only mailboxes cannot send or receive messages, you cannot:
Create distribution lists for them
Configure notification devices for them
Therefore announcement-only mailboxes cannot:
Have messages addressed to them
Have notifications cascaded to them
Receive broadcast messages
Subscribers can log in to announcement-only mailboxes using either the  TUI, VVE, or IMAP. However, there is no reason to use IMAP to log into  announcement-only mailboxes because they do not contain messages.
The following features are available only for personal mailboxes and cannot be used with announcement-only mailboxes:
Message expiration time
Message size
Fax configuration
The  following operations are available only for personal mailboxes in the  TUI and VVE and cannot be used with announcement-only mailboxes:
Playing new, saved, or deleted messages
Sending messages
Setting message parameters, such as configuration lists or notification devices
SUMMARY STEPS
1. configure terminal
2. voice mailbox owner name type announcement-only [size seconds]
3. end
4. show voicemail detail mailbox name
DETAILED STEPS
Command or Action
Purpose
Step 1
configure terminal
Example:
se-10-0-0-0# configure terminal
Enters configuration mode.
Step 2
[size seconds]
se-10-0-0-0(config)# voice mailbox owner user-8 type  announcement-only size 60
Creates a mailbox that cannot be used to leave messages. It can only be used to make announcements.
Step 3
end
Example:
se-10-0-0-0(config)# end
Exits to privileged EXEC mode.
Step 4
Example:
se-10-0-0-0# show voicemail detail mailbox user-8
(Optional) Displays information about a mailbox.
Examples
The following is sample output from the show voicemail detail mailbox command:
e-10-0-0-0# show voicemail detail mailbox User-8
Owner:                                       /sw/local/users/User-8
Type:                                        Announcement Only
Description:                                 User1 mailbox
Busy state:                                  idle
Enabled:                                     true
Allow login without pin:          no
Mailbox Size (seconds):          300
Play Tutorial:                    false
Space Used (seconds):          17
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmconfig.html#wp1042523
So, you need CUE 7.1 to fully accomplish this.
Cheers!
Rob
"Far away from your trouble and worry
You belong somewhere you feel free" - Tom Petty
hi! The version that we are using is 7.0. Is there any other alternative to this? Thx.
