Voice command not supporting cisco 4331 ISR Router
jaleelkv
I have one router cisco 43331 ISR router to be configured for Voicde SIP ling from PSTN. when i tried to put voice cammand , its not supporting any command for voice service.,  I m thinking this may be licence isuue. because uck9 not active, can anybody confirm this.Below is result from sh licence . if licence issue what shoud i do to get licence.
version of IOS: Cisco IOS XE Software, Version 16.09.05
Router#sh lic
Router#sh license
Index 1 Feature: appxk9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: uck9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
4 Accepted Solutions
M02@rt37
Hello @jaleelkv,
"uck9" feature is in an "EvalRightToUse" state, which means it's an evaluation license that has not been activated. This could be the reason why the voice commands are not working.
Please enter @Nithin Eluvathingal command suggested.
This command should activate the "uck9" license.
Best regards
@jaleelkv
Do
licence boot level uck9
And answer <yes>
license boot level sets the overall license level for the entire router, license boot module allows you to set the license level for specific modules or subpackages.
Best regards
@jaleelkv
You are in EvalRightToUse.
Do
license right-to-use activate (move) uck9 to be in permanent
Reload again after that and check the license status.
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
Best regards
12 Replies 12
Do the above.
Response Signature
it showing below command only
Router(config)#license boot?
boot
Router(config)#license boot ?
level which level to boot
suite which suite to boot
Router(config)#license boot le
Router(config)#license boot level ?
appxk9 Appx License Level
securityk9 Security License Level
uck9 Unified Communication License Level
@jaleelkv
Do
And answer <yes>
Best regards
But still not working voice command
even after boot using
licence boot level uck9, i cant enter voice commmand, licence showing   60 days validity as below
Feature: uck9
Period left: 8 weeks 4 days
License State: Active, Not in Use, EULA accepted
License Priority: Low
M02@rt37
Hello @jaleelkv,
Best regards
i found as below.. whicch one shoud i use
boot
Router(config)#license boot suite ?
AdvUCSuiteK9 Advanced Unified Communication Suite
FoundationSuiteK9 Foundation Suite
jaleelkv
Thank you all.. now i can use voice command , but i have one doubt. what will happend after 60 days of licence validity . can anybody help me regarding this
Now uck9 licence remaing only 59 days as below
Period left: 8 weeks 3 days
Period Used: 6 minutes 26 seconds
@jaleelkv
Do
Best regards
RTU after 8 weeks it will move to permanent.
upgrading to latest version  you must  connect with a smart account
Response Signature
Thank you for your valuable reply.
Now i have another issue for this router . when booting it showing
flash_check: Flash disk qu
ota exceeded [free space is 576688 kB] - Please clean up files on bootflash
router is experiencing too much slow
Also i saved all concfiguration by wr mem command and when i reboot all
configuration gone.
may be this issue related flash memmory. how can fix
Highly recommended to remove unwanted files from flash.
removing old iOS images will free up space.
Response Signature
