Voice commands for ISR 891W
Gcasonis97
Hello, I need help to configure a dial-peer on ISR 891W, when I try to configure, the command doesn't appear, the device don't support it? or there is other way to configure a SIPTrunk on this device?
Router(config)#dial-peer ?
% Unrecognized command
Router(config)#dial?
dialer dialer-list
Thanks.
Is it licensed for voice services?
Response Signature
The license is this one "CISCO891W-AGN-A-K9", I'm not sure if it supports voice services
That is the product SKU for the router, not the license. I looked up the data sheet for that router and from what I can tell there is no mention of voice services.
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
Response Signature
Firstly, it’s important to understand the purpose of having a SIP trunk on this router, especially considering this device doesn’t support any type of voice port or phone registration features.
As far as I know, these devices are typically used for security and wireless functions, not for voice.
Voice configurations cannot be performed on these routers.
Response Signature
