01-17-2024 03:23 AM - edited 02-13-2024 07:37 AM
Hello All, One of my customers recently reported their inability to make outbound calls. The ISP has been contacted, and they have been insisting there's a loopback on the router, but I have logged on to the router and there is no loopback.
01-17-2024 04:27 AM
is this your edge device connected to your provider ? You are getting a remote alarm; unless you have changed your configuration, the problem is at the ISP end (more evidence of this are the line code violations).
You could try and toggle the Framing (CRC4) and Line Code is (HDB3) parameters in your controller, sometimes that resets the connection. Toggling means to set it to any of the other options, save the config, and then set it back to the original option.
I would contact the ISP again and insist to check on their side...
That said, who is your ISP, and what country are you in ?
01-17-2024 08:55 AM
Hello Georg
Thank s for your response but the issue is still not resolved.
any other assistant is highly appreciated.
01-17-2024 09:05 AM
Hi ,
Please post the running config and a show isdn status .
Carlo
01-18-2024 01:02 AM - edited 02-13-2024 07:39 AM
Hi Carlo
thanks
01-18-2024 05:20 AM
Hi ,
I need a screenshot from CUCM of gateway configuration.
Please post it here
Carlo
01-18-2024 12:34 AM - edited 02-13-2024 07:44 AM
Hi Carlo
SRST-HQ#
This is the ISDN STATUS:
SRST-HQ#
SRST-HQ#sh isdn stat
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 12
Total Allocated ISDN CCBs = 0
SRST-HQ#
01-18-2024 02:22 AM - edited 01-18-2024 02:22 AM
From what is showed on your output "TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED" it demonstrates that your E1 circuit is not established and that's why you can't receive any call.
This issue is usually generated by a misconfiguration of isdn parameters (encoding, circuit type).
I saw that you are using MGCP as protocol with your cucm and you should check the configuration there.
Can you please post a screenshot of your gateway configuration on CUCM?
Carlo
01-18-2024 08:38 AM - edited 02-13-2024 07:45 AM
Hi Carlo
Here is it
01-19-2024 11:15 AM
@SOLID Carlo is asking you for a screenshot of the gateway and interface configuration from your Communication Manager, not from your IOS gateway.
01-18-2024 09:23 AM
35 Line Code Violations, 864 Path Code Violations,
20 Slip Secs, 9 Fr Loss Secs, 22 Line Err Secs, 0 Degraded Mins,
We see slip seconds and violations.
Check Switch type, line code and framing, confirm with Telco.
Collect 'debug isdn q921' and notify Telco that you are receiving these messages.
Cross check that they are using isdn protocol-emulation as network?
01-18-2024 09:31 AM
This is the running configuration of the VG but I need a screenshot from the CUCM.
Here an example
Can you provide it ?
Carlo
01-19-2024 09:44 AM - edited 02-13-2024 07:47 AM
01-19-2024 11:02 AM
On that page click on the E1 port icon (next to 0/0/0) and post a screeshot of all configuration page.
Carlo
01-22-2024 01:07 AM - edited 02-13-2024 07:47 AM
Hi Carlo,
This is the screenshot of the E1 port
