Voice Gateway
mohamed-gheta
Dear Cisco team,
I need to get voice gateway serial number, actually I noticed that:
show hardware
is not giving the right serial number, because I tried this command and I checked the label on VG itself
So I need your help to get the SN as I have many VG without label
VG type: AS5300 and AS5400 series
IOS 12.4(15)T7
5 Replies 5
Try show version or show inventory.
I tried both before
Show invetory
show only the modules SN
Show version
Do not show up the serial number I got from the label for all the VGs I checked physically
So please advice
Thanks for your concern
Not all cisco product can show S/N with software commands.
So if the label is physically missing, there's no way to know.
Hi bevilacqua
This will be a problem as I don't have labels on many voice gateways
how to confirm that those VGs cannot be retrieved the SN?
What do you want to confirm? It's not possible, that's all.
