05-15-2024 12:41 AM
Hello, I would like to achieve the following requirement: Dial 307, if there is no answer after 5 seconds, transfer to 382; if there is no answer after 5 seconds, transfer to 363; if there is no answer after 5 seconds, finally transfer to a specific number.
Here is my configuration:
voice hunt-group 1 sequential
pilot 307
list 307, 382, 363
final 321
timeout 5
voice register dn 74
number 307
name Bao Kaiwen
label Bao Kaiwen - 307
voice-hunt-groups login
The current situation is that when I dial 307, it directly transfers to 382, then to 363, and initially, 307 does not ring
Thank you for your help
Solved! Go to Solution.
05-15-2024 03:11 AM
Hi Kaiwen,
Either use a different number for the hunt pilot or if you need the pilot number to be 307, assign a different extension for "voice register dn 74" and include the new number in the hunt list.
Rajan
Please mark all useful posts as helpful and solutions as accepted wherever applicable
05-15-2024 03:11 AM
Hi Kaiwen,
Rajan
