03-29-2008 02:26 AM - edited 03-15-2019 09:43 AM
I am having a very weird problem on E1-pri card on NM-1CE1T1-PRI module.
After I configured the pri-group timeslots 1-31,16...I noticed the associated voice-port 1/0:15 was not created. Interface serial 1/0:15 was created.
When I do a sh ip int br...The ints1/0:15 status shows reset....
as shown below:
Serial1/0:0 unassigned YES unset reset down
Serial1/0:1 unassigned YES unset reset down
Serial1/0:2 unassigned YES unset reset down
Serial1/0:3 unassigned YES unset reset down
Serial1/0:4 unassigned YES unset reset down
Serial1/0:5 unassigned YES unset reset down
Serial1/0:6 unassigned YES unset reset down
Serial1/0:7 unassigned YES unset reset down
Serial1/0:15 unassigned YES unset reset down
My config looks like this...
card type e1 1
network-clock-participate slot 1
isdn switch-type primary-net5
Controller e1 1/0
interface Serial1/0:15
encapsulation hdlc
no ip address
isdn incoming-voice voice
no cdp enable
Solved! Go to Solution.
03-29-2008 03:01 AM
NM-1CE1T1-PRI does not support voice.
03-29-2008 03:01 AM
03-29-2008 04:33 AM
Thank you!!!!!!!!
03-29-2008 11:10 AM
You're welcome. Thanks for the nice rating and good luck!
