Hello, everybody!
need help!
I have CUCM 7.1
I have a lot of "phone+PC" sets where PS' cable inserted in a phone. and phone is going into the switch
I've discovered that when I put a big shunk of data from PC to anywhere the voice from me is degraded. the other side receive a lot of voice drops.
it repeats even if both the phones are on the same switch.
I looked into the "show interface". there is no drops in input queue of my interface.
maybe the built-in switch in the phone works not good...
please help :)
Hi Mohammed al Baqari
I have already configurated qos on l2
sh mls qos input-queue
Queue : 1 2
buffers : 66 34
bandwidth : 90 10
priority : 0 10
threshold1: 8 34
threshold2: 18 66
sh mls qos maps
Policed-dscp map:
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 00 01 02 03 04 05 06 07 08 09
1 : 10 11 12 13 14 15 16 17 18 19
2 : 20 21 22 23 24 25 26 27 28 29
3 : 30 31 32 33 34 35 36 37 38 39
4 : 40 41 42 43 44 45 46 47 48 49
5 : 50 51 52 53 54 55 56 57 58 59
6 : 60 61 62 63
Dscp-cos map:
0 : 00 00 00 00 00 00 00 00 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 03 03 03 03 03 03
3 : 03 03 04 04 04 04 04 04 04 04
4 : 05 05 05 05 05 05 05 05 06 06
5 : 06 06 06 06 06 06 07 07 07 07
6 : 07 07 07 07
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 46 48 56
IpPrecedence-dscp map:
ipprec: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 40 48 56
Dscp-outputq-threshold map:
d1 :d2 0 1 2 3 4 5 6 7 8 9
0 : 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01
1 : 02-01 02-01 02-01 02-01 02-01 02-01 03-01 03-01 03-01 03-01
2 : 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01
3 : 03-01 03-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
4 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 04-01 04-01
5 : 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
6 : 04-01 04-01 04-01 04-01
Dscp-inputq-threshold map:
0 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
1 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
2 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
3 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
4 : 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 01-01 01-01
5 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
6 : 01-01 01-01 01-01 01-01
Cos-outputq-threshold map:
queue-threshold: 2-1 2-1 3-1 3-1 4-1 1-1 4-1 4-1
Cos-inputq-threshold map:
queue-threshold: 1-1 1-1 1-1 1-1 1-1 2-1 1-1 1-1
Dscp-dscp mutation map:
Default DSCP Mutation Map:
6 : 60 61 62 63
and
sh run int f0/13
Building configuration...
Current configuration : 312 bytes
interface FastEthernet0/13
switchport access vlan 44
switchport mode access
switchport voice vlan 555
mls qos trust device cisco-phone
storm-control broadcast level 10.00
storm-control multicast level 10.00
storm-control unicast level 80.00
spanning-tree portfast
spanning-tree bpdufilter enable
end
will try to make another experiment. and will write soon
hello again
the output is almost the same:
sh int f0/13
FastEthernet0/13 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 64a0.e78c.258d (bia 64a0.e78c.258d)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 3/255, rxload 109/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:08, output 00:00:08, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 13118
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 minute input rate 43104000 bits/sec, 3586 packets/sec
1 minute output rate 1568000 bits/sec, 2192 packets/sec
17248421 packets input, 12858172353 bytes, 0 no buffer
Received 445183 broadcasts (337823 multicasts)
0 watchdog, 337823 multicast, 0 pause input
325768933 packets output, 36549191731 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
You have the port configured to trust the qos markings but you don't have any qos policies applied. What type of switch is this and have you tried applying auto qos to the port. It may fix your issue.
Hope this helps.
I have 2960 switch.
here is a part of "show hardware" output
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24PC-L 15.0(2)SE C2960-LANBASEK9-M
Try using the following command under the interface:
auto qos voip cisco-phone
already test your advice
the same picture
drops in a voice from me
When you tested it, was with phones on the same switch with the command applied to all ports involved?
Also, just to be sure, you are using Cisco phones, correct?
the problem side consists of the cisco phone 9951 and PC connected to the phone.
the other side is the cisco phone 6921
both sides are connected to one switch.
I run "auto qos voip cisco-phone" only on the problem port
huge traffic is going out of switch from the PC connected to 9951
Suggest applying it to both ports just to be thorough.
Also, you may want to sniff the ports to ensure the packets are being marked correctly.
