Voice Mail and CME
niall-wilkins
Hi all,
I am unable to get voice mail to work with CME and CUE. I am using a AIM-CUE module on a 2811 Router. When I dial extension 2378 it rings 4 times and then I get a busy signal and I am not prompted to leave a message. This setup is running in a lab environment I think that I am clearly missing something obvious. I have attached a copy of my config.
interface Service-Engine0/1
ip address 10.1.20.1 255.0.0.0
service-module ip address 10.1.20.2 255.0.0.0
service-module ip default-gateway 10.1.20.1
dial-peer voice 1 voip
destination-pattern 2378
session protocol sipv2
session target ipv4:10.1.20.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2300 voip
destination-pattern 2300
session target ipv4:10.1.20.2
codec g711ulaw
no vad
telephony-service
load 7970 TERM70.7-0-1-0s
max-ephones 4
max-dn 10
ip source-address 192.168.10.1 port 2000
time-zone 5
create cnf-files version-stamp Jan 01 2002 00:00:00
dialplan-pattern 1 6135972378 extension-length 4
dialplan-pattern 2 6135972379 extension-length 4
dialplan-pattern 3 6135972372 extension-length 4
voicemail 6135972378
max-conferences 8 gain -6
web admin system name admin password Password!
ephone-dn 1 dual-line
number 2378
name John Doe
call-forward busy 2300
call-forward noan 2300 timeout 10
ephone-dn 2 dual-line
number 2379
name Peter Smith
ephone-dn 3 dual-line
number 2372
name Test User
ephone 1
mac-address 0014.F245.0553
type 7970
button 1:1
ephone 2
mac-address 0014.F29C.DD6F
type 7970
button 1:2
ephone 3
mac-address 0014.A8A7.7F42
type 7920
button 1:3
7 Replies 7
Marwan ALshawi
what i would suggest you to do first
chnage the interface Service-Engine0/1 config as following
creat a loop back interface like
interface loopback 0
then
ip unnumbered loopback 0
then creat a static route as following
ip route 10.1.20.2 255.255.255.255 Service-Engine0/1
good luck
if helpful Rate
I have made the changes but the same thing happens. When I call extension 2378 after 4 rings I get a busy signal. These are the changes I made.
interface Loopback0
ip unnumbered Loopback0
try to use the following link will help u to check if u have somthing missing in ur config
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
good luck
if helpful Rate
This link you sent is what I used to set all this up. However as mentioned somewhere in my config I am missing something.
can u add the following config then let me know
sccp local [same ip aource add interfacelike Fa0/0]
sccp ccm [its ip address] identifier 1 version [ur cme version]
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register mtp001c58551650
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 2
associate application SCCP
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 2
sdspfarm tag 1 mtp001c58551650
good luck
Thanks for the response but I was actually able to get it to work by changing the service-module ip address from 10.1.20.2 to 192.168.10.2 and creating a route.
thanks for the respsonses
cool
please, rate the helpful Rate
