voice mail and mwi
bluesea2010
Level 5
Level 5
If voice mail is sent as an attachment  to email , if it  played by the user , mwi can be turned off ?
Dennis Mink
yes if you use unity/exchange integration, as soon as the message is read the MWI will go off.
if this is not working, state your integration and versions.
thanks
Please remember to rate useful posts, by clicking on the stars below.
If you use unified messaging then, yes. If you using send email action only
then, no.
