voice-port 0/1/0:15 not dispalyed on ay cisco ISR 4321
akram.root
Level 4
Level 4
Hello all,
I have a cisco ISR 4321 , i would configure E1 , but the port 0/1/0:15 not diplayed in gateway.
you can receive the config below.
can you help me please
Best regads
Akram
can u try the command under controller E1and check.
pri-group timeslots 1-31 voice-dsp
regds,
aman
11 Replies 11
M02@rt37
Hi @akram.root
You have got this message on your sh run config @akram.root:
! card type command needed for slot/bay 0/1
Please @akram.root check the gw-isr4431-1.txt file that you have posted first.
Just above your enable password Didata2018 command you have:
I don't see any controller e1 also.
Do you configure card type e1 command? And after configure the controller interface.
Best regards
thank you for your reply ,
i not have this message on sh run
 i configured card type e1 command and controller interface but d'ont work
Hi Akram,
You have available PRI E1/T1 slot and I can see you have configured the e1 controller.
You need to create the pri-group under the controller.
Isdn switch-type primary-ni
Controller e1 0/1/0
Please refer the discussion :
https://supportforums.cisco.com/t5/ip-telephony/voice-ports-not-showing-up-on-isr-router/td-p/2053084
Prassha3
Rate if you find this helpful
I tested but not displayed voice-port 0/1/0:15
Best regards
I have configured
card type e1 0 1
best regrds
yes i configured e1 after i configured controller e1
best regards
Prashant Sharma
Hi Akram,
Let me know if you are able to set the card type and controller type. If not can you share the output for show controller and show inventory.
eg : card type e1 0:15
controller e1 0:15
You can refer the document for configurations :
https://www.cisco.com/c/en/us/td/docs/switches/metro/me3600x_3800x/software/release/15-2_4_S/chassis/configuration/guide/3600x_24cxscg/sw_T1-E1.pdf
Prassha3
you can show the controller,inventory and ip interface brief below.
Best regads
regds,
aman
yhank you very much
it is displayed now
thank you for your help
Best regards
