Voice-Port Busyout feature not working on Cisco 2800
oslopez
Hello Everyone,
I am dealing with a basic setup where I need to make a router equiped with a FXS card to generate a busyout tone when losing contact to the gatekeeper so that the PBX will rollover calls to another gateway. In principle that can be done by implementing the "busyout monitor gatekeeper" comand, however, once the ports are in busyout status, the port remains silent and does not gererate a busy tone.
The system's details are:
Router: NAME: "2811 chassis", DESCR: "2811 chassis" PID: CISCO2811
VID: V09
FXS Card: NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(3)T4, RELEASE SOFTWARE (fc1)
Compiled Thu 24-May-12 01:37 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Router uptime is 17 minutes
System image file is "flash:c2800nm-adventerprisek9-mz.151-3.T4.bin"
When the gateway contact is lost, the ports enter in busyout mode:
Router#sh voice busyout
Voice port busyout will be triggered by the
following network states
0/1/2 busyout monitor Gatekeeper
0/1/3 busyout monitor Gatekeeper
0/3/2 busyout monitor Gatekeeper
0/3/3 busyout monitor Gatekeeper
The following voice ports are in busyout state
0/1/2   is in busyout state caused by lost of Gatekeeper connection
0/1/3   is in busyout state caused by lost of Gatekeeper connection
0/3/2   is in busyout state caused by lost of Gatekeeper connection
0/3/3   is in busyout state caused by lost of Gatekeeper connection
But as I said, no busyout tone is present at the ports, they just keep silent.
Is this a Hardware bug? Is there any patch or workaround for this problem? or am I missing something in the voice port configuration?
voice-port 0/3/2
echo-cancel coverage 24
cptone FR
timeouts interdigit 3
description FXS Line 3
caller-id enable
voice-port 0/3/3
cptone FR
description FXS Line 4
caller-id enable
I already tried several IOS versions but in all cases I get the same results.
Any clue would be appreciated.
Thank you.
Did you try it with the voice class,,
voice-class busyout 40
then apply the class to the needed port
Haitham
