06-07-2016 04:32 AM - edited 03-18-2019 12:00 PM
Dear All,
When I configure any sip phone on CME 10.5, I had to execute create profile command twice under voice register global and the phones register, but I get the below error, please help me understand what does it mean? In fact there is problem but I am curious to know this.
TST-WAN(config-register-global)#create profile
%Error deleting flash:/its/jabber-config.xml (File not found)
Thanks in advance.
06-07-2016 05:05 AM
Hi Syed,
There is nothing to worry about this message. This indicates any previous config files which are removed/not there now. The one here is a jabber config file.
Rajan
06-07-2016 05:49 AM
Hello Rajan,
I am not using jabber..
06-07-2016 05:06 AM
Syed, can you post your show tech and also are the phones registering or not.
Deepak
06-07-2016 05:46 AM
