Showing results forĀ
Search instead forĀ
Did you mean:Ā
Voice register global
Syed
Level 3
Level 3
Dear All,
When I configure any sip phone on CME 10.5, I had to execute create profile command twice under voice register global and the phones register, but I get the below error, please help me understand what does it mean? In fact there is problem but I am curious to know this.
TST-WAN(config-register-global)#create profile
%Error deleting flash:/its/jabber-config.xml (File not found)
Thanks in advance.
Rajan
Hi Syed,
There is nothing to worry about this message. This indicates any previous config files which are removed/not there now. The one here is a jabber config file.
Rajan
Hello Rajan,
I am not using jabber..
Deepak Rawat
Syed, can you post your show tech and also are the phones registering or not.
Deepak
Deepak Bro,
Phones are registering fine.
Please find the attached show tech.
