Voice translation log hits
Hi there,
I was wondering if anyone knows of a way to log the number of times that a voice translation get's used on an H323 gateway? Sort of like a hit count.
I quess the way in an access list you can put "log" at the end of the statment.
Is this going to have to be an eem script job?
Alexis
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
paolo bevilacqua
There is no way.
sort of resolved it ;-) Not sure is anyone can think of a better way of doing it
This will sent an email after the number is used 5 times....
turn "debug isdn q931" on
event manager environment _email_server X.X.X.X
event manager environment _email_to alex_XXXXX@XXX.XXX
event manager environment _ra_count 0
event manager applet MonitorNumber
event syslog pattern "0123456789" period 2
action 101 set tmp "$_ra_count"
action 102 increment tmp
action 103 cli command "enable"
action 104 cli command "config t"
action 105 cli command "event manager environment _ra_count $tmp"
action 106 if $_ra_count ge "5"
action 107  syslog msg "Conference Call number limit reached! Number:$tmp"
action 108  cli command "enable"
action 109  cli command "config t"
action 110  cli command "event manager environment _ra_count 0"
action 111  mail server "$_email_server" to "$_email_to" from "$_email_to" subject "Conference Call number limit reach on MLIV001-010CVG02_RA"
action 112  syslog msg "Email sent to $_email_to Conference Call number limit reset to 0"
action 113 end
cheers
alexis
To limit calls, you can use max-conn under dial-peer. But that is not what you have asked in the original posting.
thats correct.. to limit calls you can use max-conn
all the script dose is sent you an email telling you that the number your monitoring has been used at least 5 times... which is what i asked for in the original post .. something to monitor the number of time a number is used. Only want to monitor not block
anyway got there in the end
cheers
alexis
