Voice Translation Profile question
Lance Cutler
     What is the order of operation on voice profiles?
I have a specific interest regarding an incoming profile on a dial peer and a voice port.
Which one is first and applied?
I want to test but do not have access at this time.
So if I have a profile that translates 8885551212 on a dial peer to 81212, I have another that translates to 71212 on the voice port.
If 8885551212 is dialed which profile has precidence.
thx
Voice translation profiles (which reference voice translation rules) are referenced by the following:
  • Trunk Group - Two different translation profiles can be defined in a trunk group in order to perform number translation for incoming and outgoing POTS calls. If an outgoing translation profile is defined in a trunk group, the number translation is done while the outgoing call is setup.
  • Source IP Group - A translation profile can be defined in a source IP group in order to perform number translation for incoming VoIP calls.
  • Dial Peer - Two different translation profiles can be defined in a dial peer in order to perform number translation for incoming and outgoing calls.
  • Voice Port - The translation profile can be defined in a voice port in order to perform number translation for incoming and outgoing POTS calls. If a voice port is also a trunk group member, then the incoming translation profile of a voice port overrides the translation profile of a trunk group.
  • Non-Facility Associated Signaling (NFAS) Interface - The translation profile can be defined for an NFAS interface through the translation-profile command line from the global voice service pots configuration in order to perform the number translation for incoming and outgoing NFAS calls. This translation profile has a higher precedence than the translation profile of a voice port and trunk group in case a channel also belongs to a voice port and/or trunk group with the translation profile defined.
  • VoIP Incoming - The translation profile can be defined globally for all incoming VoIP (h323/sip) calls in order to perform number translation. If an incoming H.323/SIP call is associated with a Source IP Group with a translation profile defined, then the translation profile of the Source IP Group overrides the global translation profile for incoming VoIP calls.
Mohsin..
Looks like it takes the most specific match.
In example above it took the dial-peer match over the Voice-port.
Thanks for your help
Please rate.. if that resolved ur Question..
Mohsin.
