Voice works, data doesn't .....why?
steve.grosz
Here's the backstory.  We are moving from a Cisco 4006 to a series of 5 stacked 2960 switches.  I used the web interface on the 2960's to configure the ports for voice and data.
When I plug the 2960 G0/1 into our router, and then plug a 7960 phone into the switch, the phone configures, and I am able to make voice calls just fine.
When I plug a computer into the back of the phone (like we have set up in our offices), the computer is unable to get a IP from our DHCP server.
Did I miss something???  Why would this be happening?
There is 1 vlan on the router, vlan 274, and the voice is set to use that vlan.  I'm not sure how to get the data to go through the phone to the router and beyond.
Anyone have any ideas on what I might have missed??
35 Replies 35
Default GW for data (pc) is ?
Network for pc is?
Also i agree with paolo
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
On the switch, the default GW is the router IP, in our case its 164.165.71.1  255.255.255.0
Or is that not what you're asking?
can you describe in a short how is configured your dhcp scope?
What is the default gw for the data?
The gateway is set in the scope to 164.165.71.1 (the router itself)
what is the status of the data vlan...
please send the ff: ( just send the out relevant to the vlans)
sh ip int brief
and
sh vlan brief
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
On the router?  Or on the switch?
On the switch
Ok, here ya go
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gi0/1
274  VLAN0274                         active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Commerce_2960-SW1#sh ip int
Commerce_2960-SW1#sh ip interface bri
Commerce_2960-SW1#sh ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  164.165.71.47   YES NVRAM  up                    up
FastEthernet0/1        unassigned      YES unset  up                    up
FastEthernet0/2        unassigned      YES unset  down                  down
FastEthernet0/3        unassigned      YES unset  down                  down
FastEthernet0/4        unassigned      YES unset  down                  down
FastEthernet0/5        unassigned      YES unset  down                  down
FastEthernet0/6        unassigned      YES unset  down                  down
FastEthernet0/7        unassigned      YES unset  down                  down
FastEthernet0/8        unassigned      YES unset  down                  down
FastEthernet0/9        unassigned      YES unset  down                  down
FastEthernet0/10       unassigned      YES unset  down                  down
FastEthernet0/11       unassigned      YES unset  down                  down
FastEthernet0/12       unassigned      YES unset  down                  down
FastEthernet0/13       unassigned      YES unset  down                  down
FastEthernet0/14       unassigned      YES unset  down                  down
FastEthernet0/15       unassigned      YES unset  down                  down
FastEthernet0/16       unassigned      YES unset  down                  down
FastEthernet0/17       unassigned      YES unset  down                  down
FastEthernet0/18       unassigned      YES unset  down                  down
FastEthernet0/19       unassigned      YES unset  down                  down
FastEthernet0/20       unassigned      YES unset  down                  down
FastEthernet0/21       unassigned      YES unset  down                  down
--More--                           FastEthernet0/22       unassigned      YES unset  down                  down
FastEthernet0/23       unassigned      YES unset  down                  down
FastEthernet0/24       unassigned      YES unset  down                  down
GigabitEthernet0/1     unassigned      YES unset  down                  down
GigabitEthernet0/2     unassigned      YES unset  up                    up
Ok, so the VLAN is fine. What is the ip address of your DHCP server? Which VLAN is your dhcp server? Is it in the same vlan as VLAN 1 or is it in VLAN 274 for the IP phones. If its in a different vlan, you will need to configure ip helper-address on the router interface responsible for routing between these vlans..
Agree with aokanlawon
can you show us the config of your router?
Here is the router config:
Current configuration : 45654 bytes
! Last configuration change at 11:09:00 MST Sat Sep 29 2012 by sgrosz
! NVRAM config last updated at 18:40:48 MST Fri Sep 28 2012
version 15.1
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname 3825UCE
boot-start-marker
boot system flash c3825-adventerprisek9-mz.151-4.m.bin
boot-end-marker
no shell processing
card type t1 0 0
no logging queue-limit
logging buffered 30000000
no logging rate-limit
--More--                           no logging console
enable secret 5 $1$537v$XWXd4KCAHwUD2j4LAXvBH.
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization console
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone MST -7 0
clock summer-time MST recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
dot11 syslog
--More--                           ip source-route
ip cef
ip dhcp pool voice
network 164.165.242.128 255.255.255.128
dns-server 164.165.71.6
default-router 164.165.242.129
domain-name commerce.idaho.gov
option 150 ip 164.165.71.1
ip domain name commerce.idaho.gov
no ipv6 cef
isdn switch-type primary-ni
--More--                           voice-card 0
dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice service pots
voice service voip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
voice class custom-cptone jointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone leavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
--More--                           !
voice dnis-map 1
voice translation-rule 1
rule 1 /2083342650/ /2650/
rule 2 /2083647791/ /2159/
rule 3 /2083342470/ /2470/
rule 4 /2082873155/ /5555/
rule 5 /2082873150/ /2120/
rule 6 /2082873151/ /2105/
rule 7 /2082873152/ /2106/
rule 8 /2082873160/ /6000/
rule 10 /2082873153/ /3153/
rule 11 /2083342783/ /2783/
rule 12 /2083342681/ /2681/
rule 13 /2082873154/ /2126/
rule 14 /2082873156/ /2172/
voice translation-rule 2
rule 1 reject /2087942436/
--More--                           !
voice translation-profile INBOUND
translate called 1
voice translation-profile REJECT
translate calling 2
crypto pki trustpoint TP-self-signed-1285417314
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1285417314
revocation-check none
rsakeypair TP-self-signed-1285417314
crypto pki certificate chain TP-self-signed-1285417314
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323835 34313733 3134301E 170D3037 30383037 30303531
  32325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32383534
--More--                             31373331 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CD77 42971AAF 756433A6 EDCCE9BF C6AB9693 A28F1922 8C0AAE33 5031ED27
  DA69F41F 4295EC08 080A08FE B6634882 9C4753A4 E2BD62EE 73E4B1F8 339B9DEF
  E66FD8BE BC3093AC 73793AD7 85B1D59B 92A2A0A2 3119F031 5FC3A267 7948BB87
  611D3B94 0F6780C9 D9A584EE E21C5A7A 9957B438 1E441134 584D2D81 CC49FC6A
  89210203 010001A3 7A307830 0F060355 1D130101 FF040530 030101FF 30250603
  551D1104 1E301C82 1A333832 35554345 2E636F6D 6D657263 652E6964 61686F2E
  676F7630 1F060355 1D230418 30168014 A472EC00 FAB485B0 AD4CAFFA D94C3F3F
  B87850B5 301D0603 551D0E04 160414A4 72EC00FA B485B0AD 4CAFFAD9 4C3F3FB8
  7850B530 0D06092A 864886F7 0D010104 05000381 8100B1C5 A943BEAE 7ABDDC4F
  80293646 4D1709DC 888378A0 D022F792 F5307A67 64CB78AF 6380F2B5 7B0DB8C8
  A2491F77 E0B200B9 962AB5D4 96F06545 F6A7D322 E825A36C AA487994 D5D32590
  24890B12 99F0AD04 70B57A1E 48F12162 243EF247 C2A3FB76 CE833C5B D153BF42
  337F922A 36962C6F 250DEFB7 CACDACA9 E83DA881 1BD8
            quit
license udi pid CISCO3825 sn FTX1406A0R7
archive
log config
  hidekeys
username kimg privilege 15 secret 5 $1$y56P$bC2ziXsj1UyXLz/B0dfuP/
username Adminuser privilege 15 secret 5 $1$dFJH$e8Hc9fONnSrrMA9oJoJkZ/
username sgrosz privilege 15 secret 5 $1$uw1E$T0QEBnAGUrvvVKD/L.IBE/
--More--                           username inxadmin privilege 15 password 7 094F471A1A0A141B180F0B
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group idoc_remote
key C0mm3rc3!
dns 10.150.1.6 10.150.1.7
domain commerce.idaho.gov
pool SDM_POOL_1
netmask 255.255.255.0
--More--                           crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
interface Tunnel1
no ip address
interface GigabitEthernet0/0
description LINK TO ADMIN
ip address 164.165.88.14 255.255.255.252
ip flow ingress
ip flow egress
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description $ETH-LAN$
ip address 164.165.71.1 255.255.255.0
ip nbar protocol-discovery
ip flow ingress
--More--                            ip flow egress
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.274
description $Voice VLAN$
encapsulation dot1Q 274
ip address 164.165.242.129 255.255.255.128
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn supp-service name calling
no cdp enable
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/1
service-module ip address 164.165.71.3 255.255.255.0
service-module ip default-gateway 164.165.71.1
--More--                           interface GMPLS0
mtu 1514
no ip address
ip mtu 1500
no fair-queue
no keepalive
ip local pool SDM_POOL_1 10.150.10.10 10.150.10.20
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip flow-top-talkers
top 15
sort-by bytes
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 164.165.88.13
ip route 164.165.71.3 255.255.255.255 Service-Engine1/0
--More--                           ip access-list extended Deny_DHCP
deny   udp any any eq bootpc
deny   udp any any eq bootps
permit ip any any
logging esm config
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 remark SDM_ACL Category=16
access-list 23 permit 10.150.1.0 0.0.0.255 log
access-list 100 remark inside
access-list 100 remark SDM_ACL Category=2
access-list 100 deny   ip any host 10.150.10.10
access-list 100 deny   ip any host 10.150.10.11
access-list 100 deny   ip any host 10.150.10.12
access-list 100 deny   ip any host 10.150.10.13
access-list 100 deny   ip any host 10.150.10.14
access-list 100 deny   ip any host 10.150.10.15
access-list 100 deny   ip any host 10.150.10.16
access-list 100 deny   ip any host 10.150.10.17
access-list 100 deny   ip any host 10.150.10.18
access-list 100 deny   ip any host 10.150.10.19
access-list 100 deny   ip any host 10.150.10.20
access-list 100 deny   ip host 10.150.1.8 any
access-list 100 deny   ip host 10.150.1.11 any
--More--                           access-list 100 permit ip any any
access-list 101 remark SDM_ACL Category=2
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.20
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.19
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.18
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.17
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.16
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.15
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.14
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.13
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.12
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.11
access-list 101 deny   ip host 10.150.1.8 host 10.150.10.10
access-list 101 permit ip host 10.150.1.8 any
access-list 102 remark SDM_ACL Category=2
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.20
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.19
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.18
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.17
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.16
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.15
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.14
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.13
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.12
--More--                           access-list 102 deny   ip host 10.150.1.11 host 10.150.10.11
access-list 102 deny   ip host 10.150.1.11 host 10.150.10.10
access-list 102 permit ip host 10.150.1.11 any
route-map SDM_RMAP_1 permit 1
match ip address 100
route-map SDM_RMAP_2 permit 1
match ip address 101
route-map SDM_RMAP_3 permit 1
match ip address 102
tftp-server flash:S00105000200.sbn
tftp-server flash:S00105000300.sbn
tftp-server flash:S00104000100.sbn
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
--More--                           tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:Ring1
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
--More--                           tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
tftp-server flash:P00503010100.bin
tftp-server flash:apps42.8-5-2TH1-9.sbn
tftp-server flash:cnu42.8-5-2TH1-9.sbn
tftp-server flash:cvm42sccp.8-5-2TH1-9.sbn
tftp-server flash:dsp42.8-5-2TH1-9.sbn
tftp-server flash:jar42sccp.8-5-2TH1-9.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:SCCP42.8-5-2S.loads
tftp-server flash:apps42.9-1-1TH1-16.sbn
tftp-server flash:cnu42.9-1-1TH1-16.sbn
tftp-server flash:cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp42.9-1-1TH1-16.sbn
tftp-server flash:jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP42.9-1-1SR1S.loads
tftp-server flash:apps41.9-1-1TH1-16.sbn
--More--                           tftp-server flash:cnu41.9-1-1TH1-16.sbn
tftp-server flash:cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp41.9-1-1TH1-16.sbn
tftp-server flash:jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP41.9-1-1SR1S.loads
tftp-server flash:apps41.9-2-1TH1-13.sbn
tftp-server flash:cnu41.9-2-1TH1-13.sbn
tftp-server flash:cvm41sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp41-9-2-1TH1-13.sbn
tftp-server flash:dsp41.9-2-1TH1-13.sbn
tftp-server flash:jar41sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP41.9-2-1S.loads
tftp-server flash:term41.default.loads
tftp-server flash61.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:RingList.xml
tftp-server flash:apps37sccp.1-4-4-0.bin
control-plane
--More--                           voice-port 0/0/0:23
translation-profile incoming INBOUND
timeouts interdigit 5
voice-port 0/1/0
voice-port 0/1/1
mgcp profile default
sccp local GigabitEthernet0/1.274
sccp ccm 164.165.71.1 identifier 1 version 4.1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1.274
associate ccm 1 priority 1
associate profile 1 register MTP12345678
dspfarm profile 1 conference
codec g729br8
codec g729r8
--More--                            codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 4
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
dial-peer voice 9 pots
destination-pattern 9[2-9]......
incoming called-number .
supplementary-service pass-through
direct-inward-dial
port 0/0/0:23
dial-peer voice 91 pots
destination-pattern 91[2-9].........
port 0/0/0:23
prefix 1
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:23
--More--                            forward-digits all
dial-peer voice 9911 pots
destination-pattern 9[9,4]11
port 0/0/0:23
forward-digits 3
dial-peer voice 9011 pots
destination-pattern 9011T
port 0/0/0:23
prefix 011,,
dial-peer voice 10 voip
destination-pattern 6...
session protocol sipv2
session target ipv4:164.165.71.3
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 201 voip
description XMEDIUS FAX
destination-pattern 3153
--More--                            session protocol sipv2
session target ipv4:164.165.71.13
incoming called-number 777T
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
dial-peer voice 202 voip
destination-pattern 2783
codec g711ulaw
fax rate 14400
dial-peer voice 203 voip
destination-pattern 2083342631
--More--                            incoming called-number 777T
codec g711ulaw
fax rate 14400
dial-peer voice 204 pots
call-block disconnect-cause incoming call-reject
preference 5
destination-pattern 777T
direct-inward-dial
port 0/0/0:23
dial-peer voice 205 pots
destination-pattern 2082870768
port 0/1/0
dial-peer voice 206 pots
destination-pattern 2082870769
port 0/1/1
sip-ua
--More--                            mwi-server ipv4:164.165.71.3 expires 86400 port 5060 transport tcp
telephony-service
sdspfarm conference mute-on 111 mute-off 333
sdspfarm units 4
sdspfarm tag 1 MTP12345678
conference hardware
authentication credential sgrosz pr0gramm3r
max-ephones 150
max-dn 500
ip source-address 164.165.71.1 port 2000
service phone webAccess 0
system message Dept of Commerce
url services http://164.165.71.3/voiceview/common/login.do
url authentication http://164.165.71.3/voiceview/authentication/authenticate.do
load 7914 S00104000100
load 7935 P00503010100
load 7937 apps37sccp.1-4-4-0.bin
load 7960-7940 P00308000400
load 7942 SCCP42.9-1-1SR1S
load 7961GE SCCP41.9-2-1S
--More--                            time-zone 6
voicemail 6000
max-conferences 8 gain -6
call-forward pattern 9.......
call-forward pattern 91..........
call-forward pattern .T
call-forward pattern 2...
hunt-group logout HLog
moh commerce-hold-music.au
multicast moh 239.192.240.1 port 2000
web admin system name sgrosz secret 5 $1$j7S5$6RhRqVaBxZYAMo2twRxhO/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.......
transfer-pattern 91..........
transfer-pattern 2...
transfer-pattern .T
after-hours block pattern 1 91900 7-24
after-hours block pattern 2 91976 7-24
create cnf-files version-stamp 7960 May 31 2012 15:37:57
ephone-template  1
--More--                            softkeys hold  Resume Newcall Select Join
softkeys idle  Redial Newcall Cfwdall Gpickup Pickup Dnd Login
softkeys seized  Redial Meetme Endcall Pickup Gpickup
softkeys connected  Hold Endcall Trnsfer Confrn Park Join ConfList RmLstC Select
ephone-template  2
softkeys idle  HLog Redial Newcall Cfwdall Gpickup Pickup Dnd Login
ephone-dn  1  dual-line
number 2101
label P. Baker
description Ext. 2101
name Phillip Baker
call-forward busy 6000
call-forward noan 6000 timeout 20
hold-alert 90 originator
--More--                           !
ephone-dn  2  dual-line
number 2102
label IB Intern
description Ext. 2102
name IB Intern
ephone-dn  3  dual-line
number 2103
label Megan Ronk
description Ext.  2103
name Megan Ronk
call-forward all 95900308
ephone-dn  4  dual-line
number 2104
--More--                            label SW Conf Room
description Ext. 2104
name SW Conf Room
ephone-dn  5  dual-line
number 2105
label Beth Sparks
description Ext. 2105
name Beth Sparks
ephone-dn  6  dual-line
number 2106
label M Bartolome
description Ext. 2106
name Melonie Bartolome
--More--                            call-forward noan 6000 timeout 20
ephone-dn  7  dual-line
number 2107
label Linda Sparks
description Ext. 2107
name Linda Sparks
ephone-dn  8  dual-line
number 2108
label Debbie Jones
description Ext. 2108
name Debbie Jones
--More--                           ephone-dn  9  dual-line
number 2119
label Emily Walter
description Ext. 2119
name Emily Walter
ephone-dn  10  dual-line
number 2110
label Tom Liby
description Ext. 2110
name Tom Liby
call-forward all 2416
ephone-dn  11  dual-line
number 2111
label Tony Tenne-2111
--More--                            description Ext. 2111
name Tony Tenne
ephone-dn  12  dual-line
number 2112
label 334-2650 x2112
description Ext. 2112
name Belinda Isley
call-forward noan 6000 timeout 10
ephone-dn  13  dual-line
number 2109
label International
description Ext. 2109
name Karen Parnell
--More--                            hold-alert 90 originator
ephone-dn  14  dual-line
number 2114
label J. Sayer
description Ext. 2114
name Jeffery Sayer
ephone-dn  15  dual-line
number 2115
label M Rotchford x2115
description Ext. 2115
name Mike Rotchford
ephone-dn  16  dual-line
--More--                            number 2116
label D Bard
description Ext. 2116
name Damien Bard
call-forward all 98502963
ephone-dn  17  dual-line
number 2117
label International
description Ext. 2117
name Jennifer Verdon
ephone-dn  18  dual-line
number 2118
label B. Nertney
description Ext. 2118
--More--                            name B. Nertney
call-forward all 2105
hold-alert 30 originator
ephone-dn  19  dual-line
number 2113
label Jake Klossner
description Ext. 2113
name Jake Klossner
ephone-dn  20  dual-line
number 2120
label IT Department
description Ext. 2120
name Greg Corlett
ephone-dn  21
number 2199
label Off Hours
description Off Hours
name Off Hours
call-forward all 6000
ephone-dn  22  dual-line
number 2122
label A Braase
description Ext. 2122
name Autumn Braase
--More--                           ephone-dn  23  dual-line
number 2123
label L. Velten
description Ext. 2123
name L. Velten
ephone-dn  24  dual-line
number 2124
label Randy Shroll
description Ext. 2124
name Randy Shroll
ephone-dn  25
number 2125
label Christy Newbold
--More--                            description Ext. 2129
name Christy Newbold
ephone-dn  26
number 2126
label Steve Grosz
description 287-3154
name Steve Grosz
ephone-dn  27  dual-line
number 2127
label OST
description Ext.2127
name John Ireland
ephone-dn  28  dual-line
number 2128
label OST
description Ext. 2128
name Mark Strait
call-forward all 2139
ephone-dn  29  dual-line
number 2129
--More--                           ephone-dn  30  dual-line
number 2130
label Christine Jarski
description Ext. 2130
name Christine Jarski
ephone-dn  31  dual-line
number 2131
label Greg Seibert
description Ext. 2131
name Greg Seibert
call-forward all 99214684
ephone-dn  32  dual-line
number 2132
label Gary Hanes
--More--                            description Ext. 2132
name Gary Hanes
ephone-dn  33
number 2133
label Call Center
description Call Center
name Danita Davis - 800 Line
night-service bell
ephone-dn  34  dual-line
number 2134
label Gynii Gilliam
description Ext. 2134
name Gynii Gilliam
--More--                            call-forward noan 6000 timeout 10
ephone-dn  35  dual-line
number 2135
label Exec Conference
description Exec Conference
name Exec Conference
ephone-dn  36  dual-line
number 2136
label HR
description Ext. 2136
name Alicia Harper
ephone-dn  37  dual-line
number 2137
--More--                            label Sharon Deal
description Ext. 2137
name Sharon Deal
ephone-dn  38  dual-line
number 2138
label Gwynn Owen
description Ext. l-forward all 6000
name Gwynn Owen
ephone-dn  39  dual-line
number 2139
label Gloria Mabbutt
description Ext. 2139
name Gloria Mabbutt
ephone-dn  40  dual-line
number 2140
label Gary Moore
description Ext. 2140
name Gary Moore
ephone-dn  41  dual-line
number 2141
label Hank Ebert
description Ext. 2141
name Hank Ebert
--More--                           !
ephone-dn  42
number 2142
label Eric Forsch
description Ext. 2142
name Eric Forsch
ephone-dn  43  dual-line
number 2143
label Jerry Miller
description Ext. 2143
name Jerry Miller
call-forward all 99215289
ephone-dn  44
number 2144
--More--                            label L. McConnell
description L. McConnell
name Laurie McConnell
ephone-dn  45  dual-line
number 2145
label D Porter
description Ext. 2145
name Dennis Porter
ephone-dn  46  dual-line
number 2146
label S Davidson
description Ext. 2146
name Susie Davidson
ephone-dn  47  dual-line
number 2147
label J Howard
description Ext. 2147
name Julie Howard
ephone-dn  48
number 2148
label T. Day
description Ext. 2148
name Tacey Day
ephone-dn  49  dual-line
--More--                            number 2149
label Diane Norton
description Ext. 2149
name Diane Norton
ephone-dn  50  dual-line
number 2150
label L. Zuckerman
description Ext. 2150
name L. Zuckerman
ephone-dn  51
number 2151
label Ext. 2151
description P. Owens
name Peg Owens
ephone-dn  52  dual-line
number 2152
label Kellie Kluksdal
description Ext. 2152
name Kellie Kluksdal
ephone-dn  53  dual-line
number 2153
label C Bourner
description Ext. 2153
name Cathy Bourner
--More--                           ephone-dn  54  dual-line
number 2154
label K Ballard
description Ext. 2154
name Karen Ballard
ephone-dn  55  dual-line
number 2155
label M Knothe
description Ext. 2155
name Mitch Knothe
ephone-dn  56  dual-line
number 2156
label Nancy R.
--More--                            description Ext. 2156
name Nancy Richardson
ephone-dn  57  dual-line
number 2157
label T Caviness
description Ext. 2157
name Tina Caviness
ephone-dn  58
number 2158
label Temp Conference
description Ext. 2158
name Temp Conference
--More--                           !
ephone-dn  59
number 2159
label US Dept of Commerce
description Ext. 2159
name Amy Benson
ephone-dn  60  dual-line
number 2160
label A. Waybright
description Ext. 2160
name Anjuli Waybright
ephone-dn  61
--More--                            number 2161
label R. Nelson
description Ext. 2161
name ReNea Nelson
ephone-dn  62
number 2162
label N. Peikrishvili
description x 2162
name Natalie Peikrishvili
ephone-dn  63
number 2163
label A. Ames
description Ext. 2163
name Amanda Ames
--More--                            call-forward busy 6000
ephone-dn  64
number 2164
label Margot Wood
description M. Wood - x2164
name Margot Wood
ephone-dn  65
number 2165
label J. Hawkins
description x 2165
name Jim Hawkins
call-forward noan 6000 timeout 30
--More--                           !
ephone-dn  66
number 2166
label Call Center
name Amanda Ames -800
night-service bell
ephone-dn  67
number 2167
label Call Center
name Tina Caviness - 800 Line
night-service bell
ephone-dn  68
--More--                            number 2168
label Call Center
name Laurie Zuckerman - 800 Line
night-service bell
ephone-dn  69
number 2169
label Call Center
name Laurie McConnell - 800 Line
night-service bell
ephone-dn  70  dual-line
number 2176
label CI Intern
--More--                            description Ext. 2176
name CI Intern
call-forward noan 2151 timeout 5
ephone-dn  71  dual-line
number 2171
label Tourism - 2171
description Tourism Intern
name Tourism Intern
ephone-dn  72
number 2172
label Call Center
name Margot Wood - 800 Line
call-forward all 6201
ephone-hunt login
--More--                           !
ephone-dn  73  dual-line
number 2173
label S Scovel - 2173
description Ext. 2173
name Susan Scovel
ephone-dn  74
number 2174
label Call Center
name Karen Ballard - 800 Line
night-service bell
ephone-dn  75
--More--                            number 5555
label Andi W - 2175
description Extual-line
name MeetMe
no huntstop
ephone-dn  76  dual-line
number 2176
label CI Intern
name CI Intern
ephone-dn  78
number 2178
label Tacey Day
description Ext. 2178
name Tacey Day
--More--                            hold-alert 30 originator
ephone-dn  80
number 2180
label Server Room
description Server Room
name Server Room
call-forward noan 6000 timeout 90
ephone-dn  88
number 2188
label J. Speck
description Ext. 2188
name Jessie Speck
ephone-dn  95
--More--                            number 2195
label Call Center Messages
description Call Center Messages
name Call Center - Off Hours
ephone-dn  101
number 771
park-slot
ephone-dn  102
number 772
park-slot
ephone-dn  103
number 773
park-slot
--More--                           !
ephone-dn  104
number 774
park-slot
name MeetMe
preference 5
no huntstop
ephone-dn  105
number 775
park-slot
ephone-dn  106
number 776
park-slot
ephone-dn  107
number 777
park-slot
--More--                           ephone-dn  108
number 778
park-slot
ephone-dn  110  dual-line
number 5555
name MeetMe
conference meetme
no huntstop
ephone-dn  111  dual-line
number 5555
name MeetMe
conference meetme
preference 1
no huntstop
ephone-dn  112  dual-line
number 5555
name MeetMe
conference meetme
--More--                            preference 2
no huntstop
ephone-dn  113  dual-line
number 5555
name MeetMe
conference meetme
preference 3
no huntstop
ephone-dn  114  dual-line
number 5555
name MeetMe
conference meetme
preference 4
no huntstop
ephone-dn  115  dual-line
number 5555
name MeetMe
conference meetme
--More--                            preference 5
no huntstop
ephone-dn  116  dual-line
number 5555
name MeetMe
conference meetme
preference 6
no huntstop
ephone-dn  117  dual-line
number 5555
name MeetMe
conference meetme
preference 7
ephone-dn  118  dual-line
number 5559
name Conference
conference ad-hoc
no huntstop
--More--                           !
ephone-dn  119  dual-line
number 5559
name Conference
conference ad-hoc
preference 1
no huntstop
ephone-dn  120  dual-line
number 5559
name Conference
conference ad-hoc
preference 2
no huntstop
ephone-dn  121  dual-line
number 5559
name Conference
conference ad-hoc
preference 3
--More--                           !
ephone-dn  145
number 8....
ephone-dn  147
number 2650 secondary 2650
call-forward all 6200
call-forward noan 2100 timeout 20
ephone-dn  149  dual-line
number 2249
label Main Conference
description Main Conference
name Main Conference
ephone-dn  150  dual-line
number 2100 secondary 2470
description Danita Davis
--More--                            name Danita Davis
call-forward busy 2301
call-forward noan 2301 timeout 20
ephone-dn  151
number 2301
name Danita Davis
call-forward busy 2302
call-forward noan 2302 timeout 20
ephone-dn  152
number 2302
name Danita Davis
call-forward busy 2303
call-forward noan 2303 timeout 20
ephone-dn  153
number 2303
call-forward busy 2100
ephone-dn  154
number 2470
ephone-dn  155
number 2200
call-forward all 6202
ephone-dn  200
number 8000....
mwi on
ephone-dn  201
number 8001....
mwi off
--More--                           !
ephone  1
device-security-mode none
mac-address 000A.8A34.3DDC
ephone-template 1
username "cathy.bourner" password 1234
type 7960
button  1:53
ephone  2
mac-address 000A.8A2C.843E
ephone-template 1
username "damien.bard"
type 7960
button  1:16
ephone  3
mac-address 000A.8A2C.8C1C
--More--                            ephone-template 1
username "lisa.robbins"
type 7960
button  1:6
ephone  4
mac-address 000A.8A34.3DE1
ephone-template 1
username "julie.howard"
type 7960
button  1:47
ephone  5
mac-address 000A.8A34.3D94
ephone-template 1
username "christy.newbold"
type 7960
button  1:29
--More--                           !
ephone  6
mac-address 000A.41EB.7021
ephone-template 1
username "karen.parnell"
type 7960
button  1:13
ephone  7
mac-address 000A.8A2C.84F9
ephone-template 1
username "linda.sparks" password 1234
type 7960
button  1:7
ephone  8
--More--                            device-security-mode none
mac-address 001D.70FB.E4B0
type 7942
button  1:3
ephone  9
mac-address 001D.7061.18F1
type 7942
button  1:5
ephone  10
description Steve Grosz
mac-address 000A.8A2C.881C
ephone-template 1
username "steve.grosz"
speed-dial 1 94479511 label "Kim - Home"
speed-dial 2 98545923 label "Kim - Work"
type 7960
--More--                            button  1:26
ephone  11
mac-address 0021.5555.0898
ephone-template 1
username "renea.nelson"
type 7960
button  1:61
ephone  12
mac-address 000A.41F9.77C8
ephone-template 1
username "jake.klossner" password 1234
type 7960
button  1:19
--More--                           ephone  13
mac-address 000A.41F9.7476
ephone-template 2
username "danita.davis" password commerce
type 7960 addon 1 7914 2 7914
button  1:150 2:151 3:152 4:153
button  5:21 6:33 7m34 8m5
button  9m6 10m14 11m54 12m24
button  13m3 14m16 15m46 16m36
button  17m7 18m45 19m31 20m40
button  21m41 22m11 23m39 24m55
button  25m52 26m57 29m18 30m61
button  31m37 32m19 33m43 34m56
ephone  15
mac-address 000A.41EB.75D1
ephone-template 2
username "karen.ballard"
type 7960
button  1:54 2:74
--More--                           !
ephone  16
mac-address 000A.8A2C.8920
ephone-template 1
username "tourism.intern" password 123789
type 7960
button  1:71
ephone  17
mac-address 000A.419E.7468
ephone-template 1
username "jeffery.sayer" password pmh51569
type 7960
button  1:14
ephone  18
description Bibiana Nertney
mac-address 000A.8A2C.8642
ephone-template 1
type 7960
ephone  19
mac-address 000A.8A2C.8C27
ephone-template 1
type 7960
button  1:30
ephone  20
mac-address 000A.8A21.522A
ephone-template 1
username "lee.velten"
type 7960
button  1:23
--More--                           !
ephone  21
mac-address 000A.8A2C.85EC
ephone-template 2
username "laurie.mcconnell"
type 7960
button  1:44 2:69
ephone  22
description John Nordstrom
mac-address 000A.8A21.4FD2
ephone-template 1
username "autumn.braase" password 1234
type 7960
button  1:22
--More--                           ephone  23
mac-address 0021.5555.088F
ephone-template 1
username "Gynii.Gilliam" password vyt38222
type 7960
button  1:34
ephone  24
mac-address 000A.8A2C.9008
ephone-template 1
username "tony.tenne" password 1234
type 7960
button  1:11
ephone  25
mac-address 000A.41F9.7DE1
ephone-template 1
--More--                            username "gwynn.owen"
type 7960
button  1:38 2m45
ephone  26
mac-address 000A.8A2C.8A20
ephone-template 2
username "laurie.zuckerman"
type 7960
button  1:50 2:68
ephone  27
mac-address 000A.8A2C.8C17
ephone-template 1
username "gloria.mabbutt"
type 7960
button  1:39
--More--                           !
ephone  28
mac-address 000A.8A21.519B
ephone-template 1
username "amy.benson" password 1234
type 7960
button  1:59
ephone  29
mac-address 000A.8A21.4FDF
ephone-template 1
username "randy.shroll"
type 7960
button  1:24
ephone  30
--More--                            mac-address 000B.BEF2.D7E9
ephone-template 1
username "gary.moore"
type 7960
button  1:40
ephone  31
mac-address 00E0.7524.4872
ephone-template 1
username "directors.conference" password ghb867373
type 7935
button  1:149
ephone  32
mac-address 0007.0E36.D45E
username "tacey.day" password fdf50815
type 7961GE
button  1:78
--More--                           !
ephone  33
mac-address 000A.41F9.7E6C
ephone-template 1
username "susan.scovel" password fencer
type 7960
ephone  34
mac-address 000A.41F9.84A2
ephone-template 1
username "nancy.richardson" password 1234
type 7960
button  1:56
ephone  35
--More--                            mac-address 000A.8A21.4F50
ephone-template 1
username "anjuli.waybright" password 1234
type 7960
button  1:60
ephone  36
mac-address 000A.8A2C.8C1B
ephone-template 1
username "karen.lewis"
type 7960
button  1:1
ephone  37
mac-address 000A.416B.82F0
ephone-template 1
username "eric.forsch" password qrw988572
type 7960
--More--                            button  1:42
ephone  38
mac-address 000A.8A2C.8A6E
ephone-template 1
type 7960
ephone  39
mac-address 000A.41F9.7AB0
ephone-template 1
username "belinda.isley" password 1234
type 7960
button  1:12
ephone  40
--More--                            mac-address 000A.4158.7E35
ephone-template 1
username "gary.hanes" password 1234
type 7960
button  1:32
ephone  41
mac-address 000A.41F9.838F
username "ib.intern"
type 7960
button  1:2
ephone  42
mac-address 000A.8A21.4E55
ephone-template 2
username "tina.caviness" password 1234
type 7960
button  1:57 2:67
--More--                           !
ephone  43
mac-address 000A.8A2C.84FB
ephone-template 1
username "alicia.harper" password 1234
type 7960
button  1:36
ephone  44
mac-address 0021.5555.08D9
ephone-template 1
username "debbie.jones"
type 7960
button  1:8
ephone  45
mac-address 000A.8A21.4F4E
ephone-template 1
username "mike.rotchford" password 1234
type 7960
button  1:15
ephone  46
mac-address 001E.7AC2.DAA9
ephone-template 2
username "margot.wood" password wyo38346
type 7961GE
button  1:64 2:95 3:72
ephone  47
mac-address 000A.41F9.8398
ephone-template 1
username "hank.ebert"
--More--                            type 7960
button  1:41
ephone  48
mac-address 000A.416B.8864
ephone-template 1
username "dennis.porter" password 1234
type 7960
button  1:45
ephone  49
mac-address 000A.419E.744A
ephone-template 1
username "jennifer.verdon" password 1234
type 7960
button  1:17
--More--                           !
ephone  50
mac-address 000A.41F9.8028
ephone-template 1
type 7960
ephone  51
mac-address 000A.8A2C.85C5
ephone-template 1
username "peg.owens" password 1234
type 7960
button  1:51
ephone  52
mac-address 000A.8A2C.8538
ephone-template 1
username "greg.seibert"
--More--                            type 7960
button  1:31
ephone  53
mac-address 000A.8A2C.8AC7
ephone-template 1
username "greg.corlett" password nugget
type 7960
button  1:20
ephone  54
mac-address 000A.41F9.83B7
ephone-template 1
username "susan.davidson" password 1234
type 7960
button  1:46
--More--                           !
ephone  55
mac-address 000A.8A2C.8521
ephone-template 1
username "mitch.knothe" password 1234
type 7960
button  1:55
ephone  56
mac-address 000A.416B.87A7
ephone-template 1
username "sharon.deal" password 1234
type 7960
button  1:37
ephone  57
mac-address 00E0.7524.6C7E
username "main.conference" password 1234
type 7935
button  1:35
ephone  58
mac-address 000A.416B.7A45
ephone-template 1
username "diane.norton" password 1234
type 7960
button  1:49
ephone  59
mac-address 001D.70FC.2DBA
ephone-template 1
type 7942
button  1:4
--More--                           !
ephone  60
mac-address 001D.70FB.E3DF
ephone-template 1
username "Emily.Walter"
type 7942
ephone  61
mac-address 001D.70FB.E5E2
ephone-template 1
username "natalie.peikrishvili" password avv44692
type 7942
button  1:62
ephone  62
mac-address 001D.70FB.E31F
username "temp.conference" password dlv15270
type 7942
button  1:58
ephone  63
mac-address 001D.70FB.E488
ephone-template 1
username "jessie.speck" password xcm50394
type 7942
button  1:88
ephone  64
mac-address 0007.0E36.461B
ephone-template 1
username "beth.sparks"
type 7961GE
button  1:5 2:14
--More--                           !
ephone  65
mac-address C062.6BD3.E9D0
ephone-template 1
username "christine.jarski" password sce243754
speed-dial 1 912083745808 label "kerri"
type 7962
button  1:30
ephone  66
mac-address 000A.41F9.784A
ephone-template 2
username "amanda.ames" password rrc701323
type 7960
button  1:63 2:150 3:151 4:152
button  5:153 6:66
--More--                           !
ephone  68
mac-address 0007.0E36.D7D1
ephone-template 1
username "jerry.miller"
type 7961GE
button  1:43
ephone  69
mac-address 000A.41F9.84A0
username "server.room" password smk02819
type 7960
button  1:80 2:20 3:26 4:150
ephone  70
mac-address 0004.F2EB.30D6
ephone-template 1
--More--                            type 7937
ephone  71
ephone  72
night-service bell
ephone  73
ephone  75
--More--                           !
ephone  76
ephone  77
ephone  150
ephone-hunt 1 sequential
pilot 2082873161
list 2172, 2166, 2133, 2167, 2168, 2169, 2174
final 2200
timeout 10, 10, 10, 10, 10, 10, 10
statistics collect
auto logout 1
--More--                           !
alias configure srb do show run | begin
alias configure scav do show call active voice brief
alias configure svcs do show voice call summ
alias configure svps do show voice port summ
alias configure ses do show ephone summary
alias configure sri do show run | include
alias exec srb show run | begin
alias exec svps show voice port summ
alias exec svcs show voice call summ
alias exec scav show call active voice brief
alias exec ses show ephone summary
alias exec sri show run | include
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
privilege level 15
--More--                            password 7 1502195C03382A29256027
transport input telnet
transport output telnet
line vty 5 15
access-class 23 in
privilege level 15
password 7 03557F5B250E25414707
transport input telnet ssh
scheduler allocate 20000 1000
ntp server 164.165.210.68
end
3825UCE#
The IP address of the DHCP servier is 164.165.71.9
I'm not sure what VLAN its on, this is all running on a Cisco 4006 switch now that I'm trying to move to the 2960 switches.  I have a trunk port configured on the 4006 that goes to another switch in the building where all the servers plug in.
so
your phones have dhcp server your router
You need ip helper adress pointed to your dhcp server  in the interface g0/1 for the data
But why you dont configure another one dhcp pool for data in this router...
Well, the helper address on g/01 didn't help......  from the switch I can't ping the DHCP server, and I'm not getting an address.....
You only need the ip helper-address if your DHCP is on a seperate vlan from your data vlan. That is why I asked which VLAN it is in. Please implement my suggestions in my last post
