09-25-2009 12:21 AM - edited 03-15-2019 07:51 PM
I am having an issue with 1 user in Unity 4.2 integrated with Domino.
When a message is left in his mailbox the MWI light comes on a normal & when he checks it says there are no new messages but 1 saved message....which is the message that was just left.
I have deleted and recreated the mailbox in Domino & issue remains. Has anyone come across this before?
09-25-2009 05:19 AM
Is the mail subscriber marking the message as "read" in their mailbox?
If so, this caused the voicemail to be marked "read"
09-25-2009 05:26 AM
I'm investigating the avenue that as he has VM messages going into his email inbox also that it might be because he has an email rule setup.
Can you explain what you mean by the mail subscriber marking the message as read?? Is this a setting?
09-25-2009 05:29 AM
Is the voicemail message showing up in his email inbox?
09-30-2009 11:50 AM
UPDATE - It seems that deleting & recreating mailbox in Unity DID fix the issue after all!!
Thanks all for help - though wouldn't have needed it had i have investigated Layer 8 better :-)
09-25-2009 05:38 AM
Is it possible that the user's email client is setup to use POP? If so, by default, messages are marked as read on the server once checked by a POP email client.
Hope this helps.
Brandon
09-25-2009 05:50 AM
Thanks for responses guys,
I'm supporting this site remotely and working through the system administrator there. I'm going to find out full details of setup & i'll post results
