VOIP DHCP Pool not proper-gating to IP Phones
nexusrouter
Hello There
Due to my haste I didn't post this discussion in the correct area, I originally posted in the Video over IP instead of this one, Apologies for this.
Hopefully I will get an answer now I am in the correct area
The IP Phones do not get their respective IP addresses from the DHCP pool, however the PC hosts managaes to get their IP addresses from the Data pool. I have written the entire configuration out for you. I have tried all kinds of variations including the IP-helper facility... to no joy.
On the CME Router
Sub-interfaces on fa0/0, too create a voice and data network.
int fa0/0.1
encapsulation dot1q  4
ip address 192.168.10.1 255.255.255.0
exit
int fa0/0.2
encapsulation dot1q 5
ip address 192.168.20.1 255.255.255.0
exit
ip dhcp exclude-address 192.168.10.1 192.168.20.1
ip dhcp pool Data
default-router 192.168.10.1
network 192.168.10.0 255.255.255.0
exit
ip dhcp pool VOIP
default-router 192.168.20.1
network 192.168.20.0 255.255.255.0
option 150 ip 192.168.20.1
exit
On the switch...
Creation of Vlan 4 and Vlan 5 respectively
int vlan 4
int vlan 5
on all fa0/0 ports
switchport mode access
switchport access vlan 4
switchport voice vlan 5
exit
On the gigaport connecting to the Communication router
switchport mode trunk
IP Phones connecting to the switch are straight through as are the PC host's.
At this stage the IP phones should get their IP addresses but don't... however the PC host's manages to get their IP addresses. I also noticed that the IP Phones connected to the switch ports are navigated to the data vlan instead of the VOIP lan.
I am not included the telephony-services, ephone, mx-dn configuration,
telephony-services
ip source-address 192.168.20.1 port 2000
max-dn 10
max-ephone 10
ephone-dn 1
4001
ephone-dn 2
4002
etc etc......
The only configuration I have asertained in regards to the VOIP is below... this is not completed and in a very basic state, mainly due to not getting basic functionality with the DHCP VOIP Pool to the IP phones.
Can anyone please help????
This is all done in Packet Tracer.
rcrumm_2
Level 2
Level 2
HI,
Is cdp advertise-v2 turned on? It would need tis command to see the voice vlan.
HTH,
randall
Thank you for the suggestion,
This was one of the first things I checked, through experience I know not having the no cdp advertise-v2 turned on would cause havoc on vlan trunks carrying voice traffic and IP phone connectivity.
Still a head scratcher on this one !
Can you try configuring a single port oln
the switch in to VLAN 5 only
int fa0/X
shut
no switchport access vlan 4
no switchport voice vlan 5
switchport access vlan 5
no shut
exit
Then see if this phone gets an ip address from
the Voice pool
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
