7965 support
Robert Prideaux
Could anyone tell me if this unit is supported on the Cisco SRP527W router/modem?
I can register with the SIP provider (info screen in router) but cannot get past "registering" on the phone itself.
(need to use wireless broadband, hence the 527 unit).
paolo bevilacqua
Cisco does not document or support their Enterprise phones for third party systems, and the matter is not discussed here. You can have better luck on forums like voip-info.org.
Paulo,
since when was a CISCO router /nodem a "third party system"???
Hi Robet,
Have you upgrade the phone to SIP? By default, Cisco 79XX run SCCP. Did you try registering a SIP softphone?
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Yes thanks Leo, also used a 525G and have same issue. Assumed as SRP527 is basically an above average gateway, not a CM, that SIP would be the default?
