voip dial-peer down
philip moore
Dear All
Today I encountered an issue with a voip dial-peer
With no configuration change, the dial-peer went into down/down status.
Does anyone know what circumstances would cause this?
To be clear, the dial-peer was not shut via CLI
Phil
dksingh
Are u able to share this voip dialpeer along with sh dial peer voice summ output?
Wondering if you have a ping or busy out feature configured that can take down a
dialpeer dynamically if u lose network connex.
sure, thanks for looking at this.
This is it now after I did a no shut on the dial-peer
ROUTER#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
190000 voip  up   up             190[1,3-9]...      0  syst ipv4:1.1.1.1
190200 voip  up   up             1902...            0  syst ipv4:2.2.2.2
91900  pots  up   up             9190T              0                      up   3/0:15
91901  pots  up   up             9190T              0                      up   3/1:15
Before it was like this
dial-peer hunt 0
             AD                                    PRE PASS                OUT
190200 voip  down   down             1902...            0  syst ipv4:2.2.2.2
config is:
dial-peer voice 190200 voip
description UNMIS Juba
max-conn 15
destination-pattern 1902...
progress_ind setup enable 3
progress_ind connect enable 8
signaling forward unconditional
session target ipv4:10.130.176.110
dtmf-relay h245-alphanumeric
codec g729r8 bytes 40
fax-relay ecm disable
fax rate 7200
fax nsf 000000
fax protocol cisco
ip qos dscp cs5 media
ip qos dscp af41 signaling
ah, one thing I noticed. I have a max-conns on this dial-peer. If we reached the 15 calls would the dial-peer shows as down/down?
No, I don't think once u hit configured max-conn, the dialpeer admin and oper status
should go down. What you would see is a msg similar to following in the logs...
%CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer
There is something else going on which is taking that voip dialpeer down and don't think
its the max-conn CLI.
What do u see for sh dial-peer voice
