Have UC520 running telephony 7.1 from IOS v12.4(22)YB6 with 7945 and 7965 phones running firmware 8.54s. CUE is v7.03. Have 3 operators with 7965 phones with 3 shared lines between them for incoming calls. Intermittently when one of the operators...
Hi everybody, How can I reduce the roaming of my wireless ip phone that's taking a lot of time, without ACS and without controller. Thank you.
Hi AllOn Call Manager 7, I want to be able to automatically forward calls to a message minder.When both receptioists are busy, phones continue to ring. I want to be able to direct those calls to an automatic number where they will be greeted by a - "...
Morning all,We have a CUCM 7 and when trying to pull simple call manager traces from all nodes - 5 Nodes in all, using a 5 minute timescale zipped or unzipped takes up to 40 minutes to retrieve. There are no issues with connectivity and everything wo...
HI all, I was wondering if anyone has had any success with doing ICTs between these two call manager versions?I have a customer that is looking to make the big transition and they are looking to have a test group on the new version.I was looking to ...
Hi All,Our agents use EM to login the phone. If we configure CME in SRST mode in order to get contact center work during the WAN connection failure to hub CM, is EM still supported when CME is in SRST mode? Can I preduild the EM configuration for CME...
Hey guys --Is it possible to change the greeting via the Caller Input in Unity Connection? For instance, a user calls in and the greeting is in English, but you can press 1 to hear the greeting in French instead?I checked caller input, but didn't se...
We try to install CUCM8.0X, CUPS8.0X and UnityCN8.0X on MCS7825-I4 V03 server, but it always show the error "NOT Supported Hardware".We checked the document Supported Devices Table for Cisco Unified Operations Manager 8.0 [Cisco Unified Operations M...
I have two 9971s that are unable to complete a video call. They are built and fully functional but audio only.TIA,Amir
Hi,i have customer with CUCM cluster 7.1.3 and we have integration with AD. Since the AD have many users in which some have IP phones and some not. the customer is asking if we can have customized coorporate directory in a way that we can include the...
Good Morning NetPros,Has anyone successfully tested a DRS restore, CUCM version 7.1.3, without affecting production? I would like to be confident that the DRS backups generated are actually going to work if a restore procedure is ever needed. Now tha...
Dear AllToday I encountered an issue with a voip dial-peerWith no configuration change, the dial-peer went into down/down status.Does anyone know what circumstances would cause this?To be clear, the dial-peer was not shut via CLIThanksPhil
Hello, We just installed a new CUCM system. We don't have any managed services, so I was wondering if anyone knows how to update the greeting within one of our call handlers?I know there is an option to record via phone within the settings, but our...
I am running Unity Connection v8 ( we have same problem with v7 on another site ) and am trying to fix the problem with caller ID for external calls . When i get a call from external line and caller leave voice mail message the caller ID should be ...
I need to upgrade the Cisco Call Manager version 6.0.1 to the release 6.1.2, this upgrade is direct?
Subject | Author | Posted |
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
