Voip GSM Gateway with Callmanager
tasso.osvaldo
I need some help..
I want to redirect all my cell phone calls to one Voip GSM Gateway (the cheapest and mor easy to implement). What appliance or solution do you recommend?
Tks a lot
gogasca
Level 10
Level 10
Could you please provide the exact call flow.
Not sure if you want to do SNR or Telular...
I would suggest Quescom 300 . Please take a look at http://www.quescom.com/products.asp
We installed this system in UK for a customer and we got a good feedback from the customer.
Hello Andreas,
I have cucm 11.5 deployed in my firm. I would like to integrate it to gsm network so that VoIP users will be able to call gsm cell phones. Which device is recommended ?
