VoIP - IP phone restarting
usskenet
Guys,
we have VoIP in our company. IP phones are connected to different types of switches. Some phones still restart approximately five times per hour.
Where is problem?
Details:
Type of phone: CP-7962G
Version of phone: SCCP42.9-3-1SR2-1S
Debug display: (1SR2.1S) Last=TCP-timeout
Phone connected to switch: WS-C2960-24TC-L
IOS of switch: c2960-lanbasek9-mz.122-55.SE7.bin
Jaime Valencia
You need to look at the logs from the phone and also to any PoE/switch issue to try to determine exactly what is going on.
Even if there's a TCP timeout from the CUCM, it should not restart, just keep trying to find the CUCM server.
java
if this helps, please rate
Java,
The switch is a non-PoE switch.  So the phones could either be powered using a brick or injector.  Since the switch is non-PoE then there is a possibility that the link between the injector to the phone could be faulty.
