VoIP Network Readines
aquasilk0001
I want to test our internal network for voice readiness (Delay, jitter, latency, bandwidth) are there any tools commercial or free which i can use to set up a server in network and test the client from various locations in our network for VoIP readiness.
thanks
Manish Gogna
While there are third party tools available you can check the Prime Collaboration Assurance , details of the same are available here
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-collaboration/datasheet-c78-734833.html?cachemode=refresh
Manish
Where does PCA provide VoIP Readiness assessment?
Deepak Mehta
I personally have used IXIA tool which can measure these values for  more concurrent calls.
This is easy to set up and can be installed on machine or server connected  a switch port in same network at two locations and will give you results in minutes.
May be you can try a trial version.
guys thank you for your feedback, i am looking for a tool similar to MyConnectionServer.
http://www.myconnectionserver.com/support/v9/myVoip.html
but unfortunately it is a bit expensive i am looking for something similar a little bit cheaper or free.
