voip troubleshooting
dkblee
hi! Is there any simple to use voip trouble
shooting tool available? Any recommendation? Thanks.
There are multiple ways to do so but what exactly do you want to troubleshoot (Gateway , Call manager , SIP trunk , E1 , etc....)????
Amer
Jaime Valencia
Most of the time you'll be looking at debugs and/or traces depending on what you want to troubleshoots, where, what protocol, what issue, etc.
There are a few tools like the triple combo that can parse thru debugs or traces, BUT, a lot of times what you need to look won't be shown there.
So you'll end up looking at the flat file or what you captured.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
