Volume too low.
Rajan R
Hey Guys,
We are replacing Nortel with CUCM/Jabber for a thousand users. While nortel's sound is quite high and loud, jabber's is comparitively very low. Is there any way we can improve this ? Phone to phone quality is alright. But jabber to jabber is very low compared with nortel on the same systems with same headsets.
Varadarajan.R
Jonathan Schulenberg
I have run into this a few times. Historically when we install CUCM with physical IP Phones no one has noticed because the physical phones have a pretty good amp in them and the user can just adjust the volume up. Jabber/Windows (unclear who's at fault) doesn't provide as much amplification. The only other way to solve this is to adjust the volume on your PRI with intput gain and output attenuation commands.
The dangerous part here is that you can introduce echo into the environment if you allow the returned echo volume to be too close to the originally transmitted audio. You have to be careful to monitor the ERL after making any changes to ensure the echo canceller has enough of a delta to strip the echo from the received audio.
If that document doesn't make sense the only other good place I have seen this documented is in a Cisco press book Troubleshooting IP Telephony (ISBN 1-58705-075-7) starting on page 422).
Please remember to rate helpful responses and identify helpful or correct answers.
