06-16-2013 06:27 PM - edited 03-16-2019 05:54 PM
Hi guys,
Recently, my company wants to do VPN from branch office to HQ. The CUCM is located in HQ where my IP Phone is located in branch. Our branch office are currently using ASA 5540 firewall running context. Can anybody guide me on how to perform VPN to HQ for my branch office?
Many Thanks.
06-16-2013 06:49 PM
06-17-2013 06:03 AM
The link given by brian has all the information. Just to give you a brief set of points about the config as below,
CUCM
1. VPN Profile,
2. VPN Gateway
3. VPN Group
4. VPN Feature configuration
5. upload the asa certificate in CU OS admin
6. Also go to cisco unified reporting>system reports>Unified CM phone feature list>(make sure the phone model you are using listed here), if not you have to update your device pack and try again.
ASA
Step 1. Configure a Self-Issued Certificate
Step 2. Upload and Identify the SSL VPN Client Image
Step 3. Enable Anyconnect Access
Step 4. Create a new Group Policy
Configure Access List Bypass for VPN Connections
Step 6. Create a Connection Profile and Tunnel Group for the AnyConnect Client Connections
Step 7. Configure NAT Exemption for AnyConnect Clients
Step 8. Add Users to the Local Database
Please rate if this helps, by clicking the stars below.
06-17-2013 05:43 PM
Thanks brian and kaja for the reply.
The problem is I need to VPN from branch to HQ.
For your information, my CUCM is located at HQ and my HQ is using only router, no firewall where my branch is using firewall. How should I do VPN to reach my CUCM at HQ? Are there any documents or videos regarding how to configure the router and IP Phone? As far as I know, I only need to configure on my HQ site.
Correct me if I'm wrong.
Many Thanks.
