VPN from phones - 7841
carl_townshend
Hi All
Can anyone tell me how you would enable vpn on a phone from my home to connect to my call manager at my HQ.
Does the phone have built in VPN ?
Cheers
Carl
R0g22
AFAIK 78XX do not support SSL VPN. Data sheet does not list that as well. On CUCM, go to Unified Reporting >> Unified CM Phone Feature List. Do you see 78XX listed under Phone-vpn feature ?
Jaime Valencia
You'd need to use MRA for what you want.
java
if this helps, please rate
what is mra? What components do you need?
cheers
