01-29-2014 06:47 AM - edited 03-16-2019 09:30 PM
I am bit confused,
The scenarion i have Call manager version 9.1 running in Dubai,we have a two branch site in UK & newyork,between sites not interconnected.communication through VPN,user from Dubai goes to Branch site (UK),if they want to make a call from UK logging into Jabber client makes an extension calls ,instead of that users required a deskphone to make a call.
Should any one suggest me what are thing required to be done this task?
01-29-2014 07:48 AM
Any Body have configured ?
01-29-2014 12:07 PM
I am not following your question, can you describe exactly what your requirement is?
Chris
01-29-2014 09:27 PM
I want to access the Deskphone phone though VPN,there is no wan connectivity between two sites,
in branch site no CUCM,some users move to branch sites if they want to make a call to HQ site instead of jabber client,they need to use Deskphone through VPN.
01-30-2014 01:19 AM
There is a feature called Phone VPN.
The IP Phone detects if it is inside the LAN and is able to register to CUCM.
If this is not possible the phone estabishes a SSLVPN (to a Cisco ASA) and communicates through this vpn.
When this feature is configured you can take your phone to any internet connection.
See details and restrictions here:
01-30-2014 05:15 AM
Bernhard,
Thanks for your information,i will configure now.
Wat about call quality over the internet?
01-30-2014 05:19 AM
Quality can not be assured.
Depends on delay, jitter and packet loss...
I would try to use codec iLBC.
iLBC is relatively robust to packet loss and doesn't need as much bandwith as g.711 / g.722.
