Vulnerability regarding the SSH on Cisco BE6K server
nithin louis
Hi Team,
Our client ordered penetration test, and as a feedback they got recommendation on the Cisco UCS BE6K server "The remote SSH server is configured to allow weak encryption algorithms or no algorithm at all".
Please review the below mentioned updates which we got from the penetration test team.
Is there any way by which we can change the algorithms used between SSH server and client ?.
Thanks & Regards
Nithin Louis.
Vulnerability Name Vulnerability Impact SOLUTION Additional Information
SSH Weak Algorithms Supported The remote SSH server is configured to allow weak encryption algorithms or no algorithm at all. Contact the vendor or consult product documentation to remove the weak ciphers.
The following weak server-to-client encryption algorithms are supported :
  arcfour
  arcfour128
  arcfour256
The following weak client-to-server encryption algorithms are supported :
  arcfour
  arcfour128
  arcfour256
Have a look at below bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur26594/?referring_site=bugquickviewredir
8 Replies 8
HARIS_HUSSAIN
When you say
SSH on Cisco BE6K
You mean ssh to CIMC or ESXi or CUCM ?
Hi Haris,
Thanks for your reply.
I mean SSH to CUCM.....
Nithin Louis.
Can you get the CVE Number for this Vulnerability.
Hi Haris,
Thanks for your quick response.
As per this doc there is no workaround for this issue.
SSH Client and Keys Vulnerabilities
CSCur26594
Description
Symptoms:
Cisco Unified Communications Manager includes a version of OpenSSH that is affected by the vulnerabilities identified by the
following Common Vulnerability and Exposures (CVE) IDs:
CVE-2014-2653, CVE-2014-2532
This bug was opened to address the potential impact on this product.
Conditions:
Device with default configuration.
Workaround:
Not currently available.
Anyways I have opened a PDI for the same lets wait what their suggestion on this.
Nithin Louis.
As per the Bug  only option to fix this vulnerability is to upgrade to fixed Version of CUCM.
Last Modified:
Dec 7,2015
Status:
Fixed
Severity:
3 Moderate
Product:
(3)
Cisco Unified Communications Manager (CallManager)
Cisco Unity Connection Version 7.1
Cisco Unified Communications Manager Version 7.1
Support Cases:
Known Affected Releases:
(2)
10.5(1.98000.99)
7.1(5)
Known Fixed Releases:
(6)
11.5(0.98000.126)
11.0(0.98100.18)
11.0(0.98000.89)
10.5(2.10000.5)
10.5(1.98000.445)
10.5(1.98000.366)
Hi Haris,
Please review the below updates which we got from the Vulnerability test for the BE6K server.
Thanks & Regards
Nithin
S.No
Affected IPs
Vulnerability Name
Affected Port
CVSS Base Score
CVSS ID
Severity
SOLUTION
UCM
4511
172.16.175.11
22
4.3
Medium
Pending
  arcfour
  arcfour128
  arcfour256
  arcfour
  arcfour128
  arcfour256
Try to get the Exact CVE Number from the audit team that will help to narrow down the Issue.
Also have a look at below bugs
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy51220/?referring_site=bugquickviewredir
