VWIC-2MFT-E1 vs 2xVWIC-MFT-E1. Troubles. Please help
SludnevTN_2
I wanted to save one slot in my 2621XM - this is one of main reasons I have bought VWIC-2MFT-E1 instead of 2 one-head controllers. Also I installed 1 AIM-VOICE30. (I need 2 e1 PRIs with only 16 timeslots in each)
I have 2 E1 links, first - from my telephony service provider and second link from my PBX (AVAYA). So i see my future scheme this way:
controller e1 0/0
description - To Service Provider.
pri-group timeslots 1-16
controller e1 0/1
description - To PBX
I want a call arrived from SP will be sent to PBX and a call arrived from PBX well be sent to SP.
But I can not configure times slots on second e1, just see the output...
GK(config)#controller e1 0/0
GK(config-controller)#pri-group timeslots 1-16
Aug 17 18:55:49.327: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/0:15(1), changed state to up
Aug 17 18:55:49.339: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/0:15(15), changed state to up
Aug 17 18:55:50.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:0, changed state to down
Aug 17 18:55:50.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:1, changed state to down
Aug 17 18:55:50.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:2, changed state to down
Aug 17 18:55:50.035: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:3, changed state to down
Aug 17 18:55:50.043: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:4, changed state to down
Aug 17 18:55:50.051: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:5, changed state to down
Aug 17 18:55:50.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:6, changed state to down
Aug 17 18:55:50.071: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:7, changed state to down
Aug 17 18:55:50.087: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:9, changed state to down
Aug 17 18:55:50.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:10, changed state to down
Aug 17 18:55:50.103: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:11, changed state to down
Aug 17 18:55:50.111: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:12, changed state to down
Aug 17 18:55:50.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:13, changed state to down
Aug 17 18:55:50.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:14, changed state to down
Aug 17 18:55:50.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:8, changed state to down
Aug 17 18:55:51.147: %LINK-3-UPDOWN: Interface Serial0/0:15, changed state to down
Aug 17 18:55:52.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:15, changed state to down
GK(config-controller)#exit
GK(config)#controller e1 0/1
% Not enough DSP resources available to configure pri-group on controller E1 0/1
% The remaining dsp resources are enough for 17 time slots.
% For current codec complexity, 0 extra dsp(s) are required to create this voice port.
% Not all config may be removed and may reappear after reactivating the logical-interface/sub-interfaces
repeated many times.
Can somebody help?
18 Replies 18
Please confirm my correct understanding of the commands:
network-clock-participate wic 0 - this tells IOS that Controller in slot "HWIC0" will be watching for synchronization
network-clock-select 1 E1 0/0/0 - this points IOS to watch for synchronization in the exact "head" - 0.
controller E1 0/0/0 ! This head will TAKE synchronization from SP
framing NO-CRC4
description SP PRI
clock source line ! hidden
controller E1 0/0/1 ! This head will GIVE synchronization PBX
framing NO-CRC4
description PBX PRI
clock source internal
interface Serial0/0/0:15 - SP Serial
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15 - PBX Serial
isdn protocol-emulate network !!! Is this necessary?
no ip address
encapsulation hdlc
no cdp enable
Am I correct?
Yes, I told you the principles before, it's not always necessary to go over configuration.
Yes, I told you the principles before, it's not always necessary to go over configuration. - I am sorry, I really do not understand what this means... Does it means that the principle is - Answer the questions and never give a config?
Thank you anyway. Your answers were really helpful and very quick.
