Vwic T1 Alarm
balitewiczp
Level 2
Level 2
Whils turning up a PRI T1 interface, the AL light is lit as well as the CD.  The controller shows down, as the L1 of the PRI.  I would assume this means I have some type of cabling issue, but I dont understand why both lights are still lit.   Just looking for a sanity check.
thanks
Chris Deren
Sounds like cabling issue to me, replace a cable, also check lights on the smart jack.
Chris
