01-14-2015 01:10 AM - edited 03-17-2019 01:34 AM
Hii,
I update to cucm105 from cucm8.6 and I want to make some change on web access but I don't now exactly where can I find in Enterprise parameters or Service to remove or add option to user Web page. In cucm8.6 was easy because I have Corporate/Personal address book but now I cannot find the option on cucm10.5 user web page.
Any ideas?
Solved! Go to Solution.
01-14-2015 04:14 AM
What you see under Enterprise Parameters for self care portal is all you get to control, nothing else.
As to the directory:
The only option to search the directory would be to use this method (short of creating your own interface): http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/useroptions/10_5_1/CUCM_BK_U437D0F8_00_self-care-user-guide-1051.html#CUCM_TK_SBB32D1D_00
01-14-2015 02:51 AM
are u using Self Care portal ?
Note that some settings that appear in this guide may not appear when you set up your phone in Unified Communications Self-Care Portal due to the following factors:
regds,
aman
01-14-2015 04:14 AM
Hey Aman,
After update I use the Self Care Portal and I cannot find Personal/Corporate Phone Book on the interface anymore. On the cucm8.6 it was more easy then now.
I want to be able to add and remove options from user interface.
I manage to find the Self Care Portal but i cannot find the Personal/Corporate Phone Book.
Can you tell me where can I find those option in the Enterprise Parameters in cucm10.5?
01-14-2015 04:14 AM
01-14-2015 05:55 AM
[+5] to Jaime.
regds,
aman
