Webex Local Gateway Registration Issue
We are trying to register a local gateway with Webex and not able to get through.
- Webex hub has been configured as per the help.webex.com document. It generated the credentials like domain, registrar, username passwords, ect.
- Credentials provided in previous step are used to prepare the local gateway for registration.
- Webex calling compatibility has been checked (We are using ISR4321 with IOS-XE 17.x.x)
- ISR has been configured and verified as indicated for the local gateway documentation. Sanitized config attached.
- ISR never initiates the registration or invite message. The debugs go empty and show "sip-ua register" is always "no".
Please assist.
saif
15 Replies 15
@jc_adrian30 Why are you answering to a thread, that has already been resolved?
If you would have read the "accepted solution", you would have know where the problem is.
Your answer has nothing to do with the problem.
