12-08-2010 02:49 PM - edited 03-16-2019 02:20 AM
We're using 7975s and a few users would like some wireless headsets. Does anyone know where I can find some?
Solved! Go to Solution.
12-08-2010 02:54 PM
Only two makers do wireless headsets not requiring a lifter: Plantronics and Jabra. Both do work well, both are quite expensive, then you can research yourself what would be your favorite.
12-08-2010 03:38 PM
We use/recommend Plantronics. There are several wireless models. The models we have used for customers are:
CS70N. This is an "over the ear" model that was $329.95 list price when I last looked.
C361N. This is an "over the dome" (i.e. actually has an arm that goes over the crown of your head. List at the time I tested was $349.95
Both of these require the handset lifter (part HL10) ($79.95 last I checked).
You can see these and more by going here:
http://www.plantronics.com/north_america/en_US/productfinder/usage.jsp
1. Select the option "I want to look up compatibility by manufacturer make and model (non-bluetooth, non-3.5mm connector)" and click "Continue to Next Step"
2. Set the phone manufacturer to Cisco and the model to 7975 (or 7975G). Click on "Continue to Next Step".
3. You will have a list of headsets compatible with the phone you selected in step 2. You can further refine this by setting a filter to only show "wireless".
Now you have the wireless headsets that are available and compatible with the phone in step 2.
HTH.
Bill
Please rate helpful posts.
12-08-2010 04:43 PM
wjbell-ncn wrote:
...Both of these require the handset lifter (part HL10) ($79.95 last I checked).
Considering that the 7975 supports "electronic lifter", I recommend against buying a mechanical handset lifter.
12-08-2010 05:13 PM
No argument here.
12-08-2010 02:54 PM
12-08-2010 03:38 PM
HTH.
Bill
12-08-2010 04:43 PM
12-08-2010 05:13 PM
No argument here.
12-09-2010 05:50 AM
Thanks for the info!
All replies rated.
12-09-2010 06:00 AM
Hi there,
Just thought i might throw this in to add to the good info from Paolo and Bill
The feature is called HHC (Headset Hookswitch Control) with Cordless Headsets (Plantronics and Jabra) where the user will be able to answer calls from the Headset itself without the use of a Handset Lifter. We use quite a few of these setups and they are really awesome and far cleaner. For Plantonics the CS55 is well priced and works great with the HHC
For Plantronics;
With the use of an Adaptor Part # APC-4 (called the HHC Adaptor) which plugs into the Aux Port on the base of the phone allows calls to be answered and disconnected via the Headset without the use of the Lifter
HHC adapter (APC-4) Product Information
For GN Netcom/Jabra (see attached)
Cheers!
Rob
