what is post Mortem process ???
karthik ratna
Hi all ,
What is meant by post mortem process when gateway is down or WAN down or calls are not maturing ?
I was new to hear this , kindly give me some light on this
Karthik
Aaron Harrison
It's not clear to me whether you want to clarify the term 'post mortem', or how to do a post mortem... so..
Post mortem basically means 'after death' - it's used to describe an analysis of a dead person, or in this context it means 'work out why something failed, but is now working again'.
Typically in IT this means analysing logs, or admitting that you aren't logging anything and engaging in some educated guesswork!
So in your examples:
Calls failing - you would need to analyse gateway logs or CCM logs that you have collected from the time of the failure.
WAN down - again, looking at logged info from routers, or you might rely on your service provider to assist
Aaron Harrison
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
