What is Trusted Relay Point and the purpose of using it in H.323 Gateway?
vinojesh1994
Hi Guys,
lusandi
Based on this documment:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/8_0_2/ccmcfg/b04mtp.html
Check this check box to designate this media termination point (MTP) as a trusted relay point (TRP) that Cisco Unified Communications Manager can use in a network virtualization environment.
Refer to "Trusted Relay Point" in the "Media Resource Management" chapter in the Cisco Unified Communications Manager System Guide and its subtopics for a discussion of trusted relay points.
I hope this will be helpful.
Luis Sandi
The Document has restricted viewers. Is there any other document for the normal audience to refer?
Adarsh Chauhan
Level 3
Level 3
Hi ,
What is TRP?
A Trusted Relay Point (TRP) is a device that you can insert into a media stream to act as a control point for that stream.
You can think of it as a tunnel/Gate through which every RTP would go rather than end to end.
It's not something which is specific to H.323.
Example:
Please rate if helpful.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
